Please unregister my dump spi 95640 opel cd30
Hi. Thank you for the unregistration bin. Why do the files have different codes? Oryginal 2140. Unregis.. 5555. Which code is correct?
Hayssam1 (27th August, 2021)
Hi.
Please help me this radio unlocking. It is an opel CD30 with 95640 eeprom.
I need the unlock dump and sec. code
thanks: cseko
please help me!
Where is it sec. code in dump?
I need change the code.
I need this dump with 4362 code.
Changing the code of the dump will not make it work with a display correctly, will say display safe and will say disabled when viewed with opcom.
The display also stores other information from the radio which will not match and put the display into this state.
Only way is to put divorced dump into radio and then use opcom or tech2 to program.
Hello.
I need a radio NAVI CD70 unregister.
The display I havean inscription HEADUNIT SAFE .
Please any information how I can fix it.
I attach a file.
File Name: CD70navi.bin
Manufacturer: Siemens VDO CD70
EEPROM Type: 24C64 EEPROM
Model: Siemens VDO CD70
Serial Number: GM007050059485
Security Code: 5552
Hardware Number: 13187941
Part Number: 13188465
IDENT: LG
Code index: 00205
Audio Index: 02404
Wait Time: Not Running
Remaining Attempts: 10
Reset your current display & headunit.
Plug in the CD70 and then de-activate theft protection using the code above.
Changing the code does not work. Please for the next idea.
Please Reset display RGB & headunit in .bin files
Already you advised. Radio works.
