Hello
I have this AVDI unit with the passtru special function enabled / open
www.Abritus72.com
Would like to test it with VIDA but does not have the sw can anybody please help ?
I will post resault afterwords
Thanks in advance
Hello
www.Abritus72.com
Thanks in advance
Hi!
Did You test the Abritus interface with Vida Software?
I have the same interface and wondering if it's working with Vida
I recive a new unit from vendor.
Old one not send back yet and the new one make same problem.
On the K line model it seem to work but on can not working.on V40 2001 year is working but on other new car not working .
I am realy confused now.
If It helps you try push the: Thanks and REP
I do the same each time it helps.
have you tried uninstalling the dice unit then re-installing it ?
if you are using 2010a, try and update the dice firmware, but only do it if you are using 2010a, again after updating the firmware, try and uninstall then re-install it.......also have you tried doing a test via the dice program with the dice units?
Dice driver comes in VIDA disk.
DREWTECH CARDAQ m or PLUS working is perfect, because VolvoVIDA diag working only with Passthru device with supported J2534-2 protocol, not on J2534-1!!!!!!
www.sigmabit.eu
When I try to install Patch of Volvo Vida Dice 2010C, I get this error message:
".. C:\VIDA\\VidaMonitor.." missed
I can not start the program.
Can you help me please?
Is error from patch or when starting vida?
Is vida installed on C:\?
Run patch to C:\ only!
Iroll
When I try to install Volvo Vida, I get this error message:
"one of more of the components you chose, did not install"
Windosinstaller31 OK
Security OK
VIDA NOT OK
And when I try patch, this error:
"Windows can not found the file C:\VIDA\\VidaMonitor ..."
