Page 6 of 9 FirstFirst 123456789 LastLast
Results 76 to 90 of 122
  1. #76
    I need the Driver of Volvo VIDA DICE.
    It will not found automatically.
    Thanks.
  3. #78
    Top Poster + Iroll's Avatar
    Quote Originally Posted by bos1971 View Post
    I need the Driver
    Power up DiCE first with the OBDII connector and then connect DiCE to a PC via USB. Windows will automatically install the DiCE unit ?Driver? when the USB cable is connected to the USB port.
    Iroll
  4. #79
    I have installed VIDA DICE again, but same problem.
    Windows found the new hardware, but when I try to install automatically to found driver, Windows will not found it.
    Please, I need the Driver of Volvo VIDA DICE.
  5. #80
    Default Hi,
    Win7
    Control Panel\Programs and Features
    Is DiCE and DiCE USB Driver installed?
    If not installed, install from DVD and select ?VIDA Customized? on setup page.
    If they are installed try Repair.
    You sure have a lot of problems with this?
    Good Luck
    Iroll
  6. #81
    Quote Originally Posted by Iroll View Post
    Win7
    Good Luck
    Iroll
    I can not found it.
  7. #82
    Member VolvoGeely's Avatar
    Apr 2011
    Default Dice Drivers
    Drivers for the OEM dice only 2006 vida to date 2013.
    Self extracting & installing.
    Will work with existing Bluetooth and updated drivers.
    VG
    Edit : = Notes
    DiCE Software version 6.0.2.0
    What is DiCE?
    DiCE is a hardware interface between your PC and the in-vehicle network.
    What is this?
    This is the software required for your PC to communicate with the DiCE hardware.
    The DiCE software installs the following components:
    ***8226; DiCE USB device driver
    ***8226; J2534 functional library
    ***8226; J2534 library documentation
    ***8226; Diagnostic application
    ***8226; Firmware update application
    System requirements
    This software package support installation on Windows XP SP2 and Windows Vista.
    NOTE: The DiCE software does not support the x64 bit platform.
    How to install
    To install the DiCE software the ***8220;Install_DiCE.bat***8221; script must be executed within a command shell.
    NOTE: The installation must run as administrator.
    Windows XP
    ***8226; Simply double click on the ***8220;SetupDiCE.exe***8221; file to launch the installation.
    Windows Vista
    ***8226; Right click on the ***8220;SetupDiCE.exe***8221; file and select ***8220;Run as administrator***8221;.
    New features in this release
    ***8226; ISO15765/USB problem solved
    ***8226; XonXoff last frame problem solved
    VG
    Edit Add.
    BT update is for OEM only Dice
    2010A - vida
    VG
  8. #83
    alfons37's Avatar
    Default Problem
    I have same problem with my dice,cant communication with car...
  9. #84
    Apr 2011
    Whos dice ?
    OEM or ?
    What system ?
    Sweden , the problem might not be YOUR dice , It could be you..
    Please post AS much info , So help can supply the correct answer ..
    VG
  10. #85
    Default Hi,
    Driver from "2010A"
    You may have a bad clone dice.
    Iroll
  11. #86
    Apr 2011
    Your setup Dice Iroll is the same as what i posted above in a rar file without the rapid share wait.
    I just got got the VSTG -PIEX for 2011/06 .
    I'll see if i can get it posted / uploaded
    VG
  12. #87
    Default Hi,
    Someone pm me and had problems with dice clone after installing 2010D. They reinstalled 2010A that came with the clone and dice started working? Maybe the disk that comes with the clone is different? I thought driver from 2010A would be worth a try. I don?t own a clone and have no personal experience with this.
    Iroll
  13. #88
    Quote Originally Posted by VolvoGeely View Post
    VG
    Yes, please post.
    Iroll
  14. #89
    Apr 2011
    Let's Hope.
    First time ,new to this.
    VSTG :
    https://rapidshare.com/files/2452569367/VSTG-11.rar
    VG
  15. #90
    Has anybody reloaded car's software with clone Dice? Planning to buy a subscription and reload/update some software. Would like to know it the clone is allowed/able to to that.
