Page 9 of 9 FirstFirst ... 456789
Results 121 to 122 of 122
  1. #121
    London
    I am having problem to download this.
    Would you be able to send me a link please?
    (I am aware that this is not the current firmware but I need this particular version)
    Many thanks
  2. #122
    Nov 2021
    I know this is a very old post... Do these files still exist anywhere to download? I can only get the 2014 versions now and could do with a copy of the older 2011 version.
    Thanks to anyone who sees this!
    Quote Originally Posted by VolvoGeely View Post
    Drivers for the OEM dice only 2006 vida to date 2013.
    Self extracting & installing.
    Will work with existing Bluetooth and updated drivers.
    VG
    Edit : = Notes
    DiCE Software version 6.0.2.0
    What is DiCE?
    DiCE is a hardware interface between your PC and the in-vehicle network.
    What is this?
    This is the software required for your PC to communicate with the DiCE hardware.
    The DiCE software installs the following components:
    ***8226; DiCE USB device driver
    ***8226; J2534 functional library
    ***8226; J2534 library documentation
    ***8226; Diagnostic application
    ***8226; Firmware update application
    System requirements
    This software package support installation on Windows XP SP2 and Windows Vista.
    NOTE: The DiCE software does not support the x64 bit platform.
    How to install
    To install the DiCE software the ***8220;Install_DiCE.bat***8221; script must be executed within a command shell.
    NOTE: The installation must run as administrator.
    Windows XP
    ***8226; Simply double click on the ***8220;SetupDiCE.exe***8221; file to launch the installation.
    Windows Vista
    ***8226; Right click on the ***8220;SetupDiCE.exe***8221; file and select ***8220;Run as administrator***8221;.
    New features in this release
    ***8226; ISO15765/USB problem solved
    ***8226; XonXoff last frame problem solved
    VG
    Edit Add.
    BT update is for OEM only Dice
    2010A - vida
    VG
