joe06 (23rd April, 2018)
which is the software to find the pin (apv) from the dump of UCH?
I have ISK code 509716B5E499
Can you give me APV code?
what car ?
model , year
uch siemens = 05490EAB7BCC
Thanks!
UCH Siemens, Logan,2005
Sorry for offtop.
I want to add second cle for my car. I bought blank transponder pcf7936AS.Perform the procedure 1, I get an answer 2.
I have problem with transponder (3) or I incorrect use DDT?
Thanks!!!
You MUST use transponder PCF7936 ID 46 ( for renos ), there are some others ID for different cars.
You are sure it is ID 46 ?
And why didn`t you program in the first place an old key for your car and after that the newer keys ?
Try first with an old good working key, and after the newer keys.
Repeated by mistake the post downwards.
You can program only transpoder PCF7936 ID 46 ( Renault ). This is for sure. Changing the ID, i`m not so sure, maybe is working Zedbull ( never worked with that tool, sorry m8 )
You can add/remove old keys, your new keys are not ID 46, that`s why you can`t program them ! This ID is a precode and it MUST BE 46 for Renault ( factory preset ).
