Hello !
Passat TDI 140, BKP engine. 2006
Today i tried to change the defective steering column lock with a new one purchased from VW
I have the pin code, and i verified that i have security access to IMMO controller, before removing the old one.
I removed battery and i changed the lock.
After that, i plugged battery, switched on ignition and tried to get security access to immo, but the pin code was not recognised. after 3 attemt, the immo controller is locked for 250 minutes. Impossible to match the new lock.
Has anyone ever had this problem? Do you have a solution to offer?
Thank you !
