Flashing a Dbox2 using A Null Modem Cable and Hyper Terminal - Page 10
Page 10 of 10 FirstFirst ... 5678910
Results 136 to 148 of 148
  1. #136
    Nov 2008
    London
    Default No further than chorus 800000
    Following tut
    Everything goes good up to u-boot.mot
    unrecognized command ???I??@??@??&0Rl*ritten, args[0][0] 0xfa
    dbox2:root> ,???2??8???F???L???R?Y? ?
    unrecognized command ,???2??8???F???L???R?Y? ?, args[0][0] 0x2c
    dbox2:root> ?????B?B?????C???L\C???C???$D??tDD????D???,<E?d??? ???rq??t??
    ??????B?B?????C???L\C???C???$D??tDD????D???,<E?d?? ????EE?FF??? eo8/ ad 0
    2??????B?B?????C???L\C???C???$D??tDD????D???,<E?d? ?????EE?FF??? eo8/ ad
    0y27=e4m?rq??t??#+3;CScs????
    unrecognized command ??????B?B?????C???L\C???C???$D??tDD????D???,<E?d??
    ????EE?FF??? eo8/, args[0][0] 0xa0
    dbox2:root>
    dbox2:root>
    dbox2:root>
    unrecognized command , args[0][0] 0xff
    dbox2:root> ?j??????@_?? ???B??????
    unrecognized command ?j??????@_??, args[0][0] 0xf4
    dbox2:root> ??\???O??? ?????? ??N???? ??
    unrecognized command ??\???O??? ?????? ??N???? ??, args[0][0] 0x80
    dbox2:root> ?????p????????b???????
    unrecognized command ?????p????????b???????, args[0][0] 0xd0
    dbox2:root> ?X????x???????
    On this last line of code the cursor stops midway in the line code
    So I copy and paste to host chorus 800000 as soon as this is done this appears
    unrecognized command ?X????chx???????, args[0][0] 0xc4
    So I try again
    dbox2:root> chorus 800000
    and this comes up
    chorus 0x800000
    elfCopy failed: 16
    dbox2:root>
    Please advise?
  2. #137
    V.I.P. Member Fergal's Avatar
    Aug 2008
    Make sure you are doing it exactly as the tut says
    NOTE: All of the following is case sensitive. Make sure you take note of the case!
    Type in the following and hit the enter key on your keyboard:
    dl 800000 (the l is a lowercase L)
    You should now get the following message returned in the command window.
    S record load, offset: 800000
    You will not get the command prompt back at this point; it will just be stating that message above. At this point you need to click on “Transfer” from the menus at the top of the hyper terminal. In the drop down list click on “Send Text File
    You will now get a browse window to find a file. Change the ‘Type of file’ to be “All Files” from the drop down list at the bottom. You now need to navigate to the place you extracted this guide to as it also come with the files you need. So when you have navigated to the correct place, click on U-BOOT.MOT then click on open. It will now start to transfer. This will take about 5 minuets and will not show any information about it on the HyperTerminal. After about 5 minuets when it has completed, you will get the following message on the HyperTerminal and be returned to the command prompt.
    DL: start ADDRESS 0x800000
    Try this uboot file
  3. #138
    Nov 2008
    London
    Thanks Fergal for your prompt reply however i have followed both yours and Aftermath word for word copy and paste everything so that I don't get it wrong and I am still getting the same problem as per my previous email.
    Please advise?
    Quote Originally Posted by Fergal View Post
    You will not get the command prompt back at this point; it will just be stating that message above. At this point you need to click on ?Transfer? from the menus at the top of the hyper terminal. In the drop down list click on ?Send Text File?
    You will now get a browse window to find a file. Change the ?Type of file? to be ?All Files? from the drop down list at the bottom. You now need to navigate to the place you extracted this guide to as it also come with the files you need. So when you have navigated to the correct place, click on U-BOOT.MOT then click on open. It will now start to transfer. This will take about 5 minuets and will not show any information about it on the HyperTerminal. After about 5 minuets when it has completed, you will get the following message on the HyperTerminal and be returned to the command prompt.
    Try this uboot file
  4. #139
    Default same
    hi mate
    im having the same problem has you, i have a sagem box
    any help would be great
    reed001
  5. #140
    Aug 2010
    Default Hi mate
    Aftermath thks for this post though i hv'nt tried it simply bcos i hv't got the null cable but i hv placed other for it hopefully i should get next week. ill let you know how it goes.
  6. #141
    Dec 2012
    can someone help me find the u-boot.mot file?....thnx
  7. #142
    Bulld0g's Avatar
    Apr 2008
    Liverpool
    Quote Originally Posted by dannyleverman View Post
    Digital Kaos - Downloads - uboot.mot
  8. #143
    Aug 2015
    I think I need that file too.
    I have a dbox2 (Nokia 2xIntel) and it stuck at enigma boot picture. I have to give a try to flash with a null modem cable, since it doesn't want to communicate via ftp.
    So please, someone help me to get that uboot.mot file.
    Thanks.
  9. #144
    DK Veteran psats's Avatar
    Sep 2008
    Quote Originally Posted by nectarin View Post
    Thanks.
    you only need to use IFA
    http://www.digital-kaos.co.uk/forums...do=file&id=506
  10. #145
    Aug 2015
    Quote Originally Posted by psats View Post
    I have IFA, but as I said there's no communication via lan.
    So I would like to give a try to the "nul modem cable only" method. That's why I need that u-boot.mot file, but I can't find anywhere to download.
    Please help me to get that file.
  11. #146
    Sep 2008
    you need to use null modem cable with IFA
  12. #147
    Aug 2015
    I have tried it that way, but it doesn't start. It gives me an error message only.
  13. #148
    Sep 2008
    are you useing a Cross over Network cable. ?
