Page 6 of 10 FirstFirst 12345678910 LastLast
Results 76 to 90 of 148
  1. #76
    V.I.P. Member gizmo.1484's Avatar
    Apr 2008
    WestYorkshire
    Quote Originally Posted by PLAC View Post
    Hi I just got a dbox2 from a friend which won't boot. I need to download u-boot ASAP. Have null modem cable. Can anybody help?
    If your box as gone into klein system and will not boot up then you need this program>>>>>>>>>>>Digital Kaos - Downloads - Image Flashing assistant this will refresh your image just follow the guide from post 1 that should sort you out.
  2. #77
    Jan 2009
    Thanks, but I downloaded IFA a few days ago and it hangs like this below when I try to flash the last working image back.
    ?debug: DDF: Calibrating delay loop... debug: DDF: 66.76 BogoMIPS
    debug: BMon V1.1 mID 03
    debug: feID 00 enxID 03
    debug: fpID 52 dsID Hallenberg.com
    debug: HWrev 41 FPrev 0.23
    debug: B/Ex/Fl(MB) 32/00/08
    WATCHDOG reset enabled
    debug: autoboot aborted from terminal
    dbox2:root> boot net net net net net net net net net net
    debug:
    BOOTP/TFTP bootstrap loader (v0.3)
    debug:
    debug: Transmitting BOOTP request via broadcast
    debug: Given up BOOTP/TFTP boot
    boot net failed
    debug:
    debug:
    boot net failed
    debug:
    debug:
    debug: Got BOOTP reply from Server IP 169.254.68.148, My IP 169.254.68.202
    debug: Sending TFTP-request for file u-boot
    will verify ELF image, start= 0x800000, size= 140064
    verify sig: 262
    boot net: boot file has no valid signature
    Branching to 0x40000
    U-Boot 1.3.4 (Tuxbox - Hallenberg.com) (Nov 29 2008 - 23:53:59)
    CPU: PPC823ZTnnB2 at 66 MHz: 2 kB I-Cache 1 kB D-Cache
    Board: DBOX2, Sagem, BMon V1.1
    Watchdog enabled
    I2C: ready
    DRAM: 32 MB
    FLASH: 8 MB
    FB: ready
    LCD: ready
    In: serial
    Out: serial
    Err: serial
    Net: SCC ETHERNET
    BOOTP broadcast 1
    BOOTP broadcast 2
    BOOTP broadcast 3
    BOOTP broadcast 4
    BOOTP broadcast 5
    Retry count exceeded; starting again
    BOOTP broadcast 1
    BOOTP broadcast 2
    BOOTP broadcast 3
    BOOTP broadcast 4
    BOOTP broadcast 5
  3. #78
    Apr 2008
    WestYorkshire
    Have you tried flashing a different image as this might be corrupt. I don't know much about boot logs as i use just a xover cable. Are you sure the image is fine?
  4. #79
    Jan 2009
    Thanks gizmo i have also tried a backup image am going to reboot everything and try again
  5. #80
    Bulld0g's Avatar
    Apr 2008
    Liverpool
    Just uploaded the file and a tut for flashing using a null modem. Might be of use to someone.
  6. #81
    hey guys, im trying to connect the dbox to hyper terminal. but when its comes to setting up a connection, i cannot change the country/region, its stuck on uruguay (598) or the area code.
    can anyone help??
  7. #82
    DK Veteran termiantor's Avatar
    Jan 2009
    Default hyperteminal
    hi mate got a bit stuck here foolow u instructions but when transfering the image it onlt take about 7 secs any ides
  8. #83
    Jan 2009
    hi there,
    I have done everything as explained in this guide.there is a slight problem at the end.It says at the last step when i tyepd in cp.l 120000 10020000 1F8000 enter
    it says
    copy to flash ....Flash not erased
    and it does not say done after 2 mins not even after waiting 10 mins
    Please advise me with ur experience and knowledge.
    thanx a lot and regards
  9. #84
    Nov 2008
    Hi there,
    I recently tried this and the mistake I was during the 'transfer file' part. Make sure you are using the correct transfer protocol. One file you need to transfer as 'text file' and the other as 'file'
    Hope this makes sense.
  10. #85
    Nov 2008
    Don't think it matters. It greys out when you select your com port.
  11. #86
    Nov 2008
    Quote Originally Posted by kila101 View Post
    can anyone help??
  12. #87
    Jan 2009
    Default dbox flashing
    tryed everything all goes well till near the end
  13. #88
    DK Veteran psats's Avatar
    Sep 2008
    Quote Originally Posted by milne View Post
    copy paste the command lines it should flash then.
  14. #89
    Nov 2008
    I have a d digital box will this guide work on that as ive tried and all i get is the hypo terminal flashing curser no info goes on?
    Thx Claire
  15. #90
    Feb 2009
    Default hyperterminal
    where or how do i get a hyperterimal im new to this game please help
