Page 9 of 10 FirstFirst ... 45678910 LastLast
Results 121 to 135 of 148
  1. #121
    aftermath's Avatar
    Mar 2008
    Quote Originally Posted by stuckylad View Post
    when typing in chorus 800000 nothing happening,any suggetions ? cheers
    try copy and pasting from the tut, it can be easy to miss a character off or something.
  2. #122
    DK Veteran stuckylad's Avatar
    Jun 2008
    m/well
    sorry ,trying to copy the usual way ,but cant seem to paste
  3. #123
    Jun 2008
    m/well
    getting elf copy failed,after typing chorus 800000,about ready to throw this thing in the bin grrrrr
  4. #124
    Jun 2009
    Quote Originally Posted by chuckles53 View Post
    got to the part were you have a blank screen and when i held the arrow down and turned the box on nothing happend,can you help.Thanks
    when you get to the black screen in hyper terminal then plug in your null modem cable and press the up buttom and keep it pressed and then plug in your dbox and you should get the text in hyper terminal,
    ps big thanks to aftermath for the tutorial and the screen shots they realy helped me out.
  5. #125
    Member NUKEMALL's Avatar
    Default thanks
    thanks for this info lads and great work .
    killed my box friday night trying to find a stable image for my sagem (old but i like it) .
    i was using the Lincsat.Beta7.25-Full image but it keeps freezing and i need to restart it to get it to work again so i tried to flash a image using my network and yes crashed the box . copied you post word for word and got it running again .
    THANKS AGAIN FOR THE HARD WORK YOU ALL PUT IN FOR US NOOBS .
    can any one pm me where i can get a newer complete image i can play with .
  6. #126
    after installing the uboot i gote this
    unrecognized command ???Y??? r, args[0][0] 0xea
    dbox2:root> x{~???@??tB??BB?B???B???B??B?????$??CD??C??Ct????C ???C?????C????
    ??C????$?D4??DT??Dl??D???D??D???D??D???E???$?E<??E T??Et??E???E??E???E??E??????
    2x{~???@??tB??BB?B???B???B??B?????$??CD??C??Ct???? C???C?????C???C????$?D4??D
    T??Dl??D???D??D???D??D???E???$?E<??ET??Et??E???E?? E???E??E???F??$?F4??FT??Fl g
    DT??Dl??D???D??D???D??D???E???$?E<??ET??Et??E???E? ?E???E??E???F??$?F4??FT??Fl
    gnant5nd/d t=b=e080 80ete0d29e87e2.beg????
    unrecognized command 2x{~???@??tB??BB?B???B???B??B?????$??CD??C??Ct???? C???C
    ?????C???C????$?D4??DT??Dl??D???D??D???D??D???E??? $?E<??ET??Et??E???E??E???E?
    ?E???F??$?F4??FT??Fl gnant5nd/d, args[0][0] 0xa0
    dbox2:root>
    dbox2:root> ??:??k??j????/????"????lj???@_??B????
    unrecognized command ??:??k??j????/????"????lj???@_??B????, args[0][0] 0x80
    dbox2:root> ???????6??
    unrecognized command ???????6??, args[0][0] 0xea
    and i clik enter and then the commande
    chorus 800000
    and got this message
    dbox2:root> chorus 800000
    chorus 0x800000
    elfCopy failed: 16
    dbox2:root>
    and nothing more
    plaise help me
  7. #127
    stuckylad getting elf copy failed,after typing chorus 800000,about ready to throw this thing in the bin grrrrr
    follow the TUT as shown if you are copying and pasting as norm all should be ok .
    i am new to the dbox , as playing for fun at the mo ... but i have used this for atleast 6 flashes and at first i had loads of trouble BUT . started from step one and followed the tut and now its like childs play , just have the tut open for the cut and paste ....
    great work lads
  8. #128
    Oct 2008
    Can you use this to flash the d-box nokia. I dont have d-box2
  9. #129
    Smile
    hi
    im a newbie wanting to know where to download the u.boot.mot file please thanks for the help
  10. #130
    Default Most comprehensive guide i've found
    many thanks best guide and site i've found on the subject, cant wait to get stuck in, great stuff!
  11. #131
    could you tell me were i can find to download u-boot.mot
  12. #132
    Thanks for putting this info up.
    I've tried several times, holding the up buttton while powering up
    I get the following, displayed on Hyperterminal
    But thats all that happens, I'm unable to type anything.
    When I do, the curser remains in the same place and nothing happens.
    Any ideas whats happening?
    ~debug: DDF: Calibrating delay loop... debug: DDF: 67.79 BogoMIPS
    debug: LCD init error -1
    debug: BMon V1.0 mID 01
    debug: feID 7a gtxID 0b
    debug: fpID 5a dsID 01-58.4e.cb.05.00.00-61
    debug: HWrev X5 SWrev 0.81
    debug: B/Ex/Fl(MB) 16/16/08
    WATCHDOG reset enabled
    debug: &_text 0x10000, &_etext 0x26160, &_data 0x26160, &_edata 0x29c50
    debug: &_end 0x347dc, &__stack 0x400000
    debug: Memory tests (0x400000 -- 0x1000000)
    debug: NumberTest: debug: passed
    debug: MarchTest: debug: passed
    debug: PermTest: debug: passed
    debug: Extension Memory tests (0x1000000 -- 0x2000000)
    dbox2:root>
  13. #133
    Hi guys once its says "DONE" what are the nexts steps????
    reallly appreciate your help!!
    waz
  14. #134
    can someone assist me with what the next step is after it says "DONE" i live in the TW3 region (london). by doing the steps AfterMath has stated, do any need to do anything else?
    waz
  15. #135
    thanks, sounds good, i will see how this works out
