Page 1 of 10 123456 ... LastLast
Results 1 to 15 of 148
Hybrid View
    aftermath's Avatar
    Mar 2008
    Part one..
    Click on start
    then All Programs
    then Accessories
    then Communications
    then Hyper terminal.
    see pic 1.
    you should get this
    Where it says new connection type in Dbox2 or anything really. Then click ok.
    enter com1 like in picture.
    then copy the following settings.
    Then ok.
    you should see a blank screen with a flashing cursor.
    now connect the null modem cable to your Dbox2, make sure the box is switched off. Press the up arrow button on the front of the box and keep the button pressed in. Now switch the box on ( keeping the button in) you should see some text scrolling on your screen.
    When you see the dbox2:root > you can let go of the button.
    u-boot file here also RapidShare: 1-CLICK Web hosting - Easy Filehosting
    aftermath's Avatar
    Mar 2008
    Default PART 2
    part 2.
    now type in dl 800000 . Then press enter
    you should see this : S Record Load, offset: 800000
    Download the attached u-boot.mot file
    Next click on Transfer on top of hyperterminal window, select "send text file", select type of file "All files",
    select the file u-boot.mot (attached here) and click on "open" to start the transfer.
    The file transfer take about 5 minutes and in hyperterminal no announcement appears about the process of the transfer.
    You will now need to type in the following command and hit enter.
    This will start the u-boot file we just transferred.
    As this is starting it will try get a network connection, as we do not want this, we need to break out of it. You do this by holding down the control key on your keyboard and pressing the ‘C’ key at the same time. This needs to be done before 3 attempts at the connection. You will be returned to the command prompt again. So type the following command.
    chorus 800000
    Keep control key pressed when its trying to connect to the network and press the ‘C’ key and you will be returned to the command prompt. NOTE: the command prompt has changed a little bit and now looks like =>
    This is normal :>)
    should see a screen something like this.
    Now type in :- loadb 120000 115200
    You will get the following message
    ## SWITCH Baud rate to 115200 bps and press ENTER
    in Hyperterminal stop the connection
    Call -> Disconnect),
    click File -> Properties ->
    change the Bits per second to 115200.
    Click on ok and leave the menus.
    Reconnect with Call -> Call on top of the hyperterminal window.
    Press enter on keyboard.
    you should now see this command : - ready for binary (kermit) download to 0x00120000 at 115200 bps
    NOW TO TRANSFER THE IMAGE.
    On top of hyperterminal window click on Transfer then send file,
    Choose your image (image without bootloader)
    Then choose the "kermit" protocol.
    Click on send.
    you will get a screen something like this.
    This will take about 45 minutes.
    Hyperterminal shows the transfer process inside a extra window.
    After transfer u-boot announces
    ## totally Size = 0x007E0000 = 8257536 bytes
    ## start ADDR = 0x00120000
    ## SWITCH Baud rate to 9600 bps and press ESC
    Click File -> Properties -> Configure and change the Bits per second to 9600. Click on ok and leave the menu.
    Press ESC on the pc keyboard
    u-boat prompt appears again "= >"
    Type in .
    protect off 10020000 107fffff
    Press enter then type in
    erase 10020000 107fffff
    cp.l 120000 10020000 1F8000
    Wait untill it says Done.
    The procedure take about 2 minutes.
    Jun 2008
    Thanks aftermath for that will give it a whirl later on today
    Dec 2008
    Thanks for the post.
    Been trying with a crossover cable but no luck.will try with a null modem cable.
    Cheers
    Jan 2009
    hi there,
    I have done everything as explained in this guide.there is a slight problem at the end.It says at the last step when i tyepd in cp.l 120000 10020000 1F8000 enter
    it says
    copy to flash ....Flash not erased
    and it does not say done after 2 mins not even after waiting 10 mins
    Please advise me with ur experience and knowledge.
    thanx a lot and regards
    Mar 2009
    Default brilliant.....thank you so much
    really good info......thanks
    Quote Originally Posted by aftermath View Post
    part 2.
    As this is starting it will try get a network connection, as we do not want this, we need to break out of it. You do this by holding down the control key on your keyboard and pressing the ?C? key at the same time. This needs to be done before 3 attempts at the connection. You will be returned to the command prompt again. So type the following command.
    chorus 800000
    Keep control key pressed when its trying to connect to the network and press the ?C? key and you will be returned to the command prompt. NOTE: the command prompt has changed a little bit and now looks like =>
    This is normal :>)
    Click on send.
    Type in .
    Aug 2009
    Default waiting for time
    hi guys used this system, tried a few images latest one laky, still not picking up the time, waiting for time any ideas .
    many thanks .
    Jun 2008
    thanks for the inf hopefully will have a few posts soon and able to download the files needed to repair the box.
    Jun 2008
    Quote Originally Posted by jsm206 View Post
    hope so mate
    Jun 2008
    Dundee
    Default no hyperterminal in vista
    There is no hyperterminal in vista platinum....
    any idea of where to getr one (if any exist ?)
  11. #11
    Jun 2008
    Try google search for hyperterminal should be able to download from the microsoft.com website m8
    IF U FIND THE INFORMATION USEFUL PRESS THE THANX BUTTON CHEERS!
  12. #12
    Junior Member balikuyu's Avatar
    Jul 2008
    Default Cool
    I will try this now always used IFA B4
    Much easier this way well dome M8
  13. #13
    Jul 2008
    Really hope this works for me, The Wife tripped the power half way thorugh the flash
  14. #14
    Jul 2008
    Can you help me with the very last part
    I have done everything as instructed
    Very last bit i typed => cp.l 120000 10020000 1F8000
    Its now saying
    Copy to Flash. . . _
    Its like its waiting for me to do something
    Can anyone help
  15. #15
    Jun 2008
    you have to wait till it says "done",,
    <--marvo added 5 Minutes and 5 Seconds later...-->
    Type in .
