part 2.
now type in
dl 800000 . Then press enter
you should see this :
S Record Load, offset: 800000
Download the attached
u-boot.mot file
Next click on Transfer on top of hyperterminal window, select "send text file", select type of file "All files",
select the file u-boot.mot (attached here) and click on "open" to start the transfer.
The file transfer take about 5 minutes and in hyperterminal no announcement appears about the process of the transfer.
You will now need to type in the following command and hit enter.
This will start the u-boot file we just transferred.
As this is starting it will try get a network connection, as we do not want this, we need to break out of it. You do this by holding down the control key on your keyboard and pressing the ?C? key at the same time. This needs to be done before 3 attempts at the connection. You will be returned to the command prompt again. So type the following command.
chorus 800000
Keep control key pressed when its trying to connect to the network and press the ?C? key and you will be returned to the command prompt. NOTE: the command prompt has changed a little bit and now looks like =>
This is normal :>)
should see a screen something like this.
Now type in :-
loadb 120000 115200
You will get the following message
## SWITCH Baud rate to 115200 bps and press ENTER
in Hyperterminal stop the connection
Call -> Disconnect),
click File -> Properties ->
change the Bits per second to 115200.
Click on ok and leave the menus.
Reconnect with Call -> Call on top of the hyperterminal window.
Press enter on keyboard.
you should now see this command : - ready for binary (kermit) download to 0x00120000 at 115200 bps
NOW TO TRANSFER THE IMAGE.
On top of hyperterminal window click on Transfer then send file,
Choose your image (image without bootloader)
Then choose the "kermit" protocol.
Click on send.
you will get a screen something like this.
This will take about 45 minutes.
Hyperterminal shows the transfer process inside a extra window.
After transfer u-boot announces
## totally Size = 0x007E0000 = 8257536 bytes
## start ADDR = 0x00120000
## SWITCH Baud rate to 9600 bps and press ESC
Click File -> Properties -> Configure and change the
Bits per second to 9600. Click on ok and leave the menu.
Press ESC on the pc keyboard
u-boat prompt appears again "= >"
Type in .
protect off 10020000 107fffff
Press enter then type in
erase 10020000 107fffff
cp.l 120000 10020000 1F8000
Wait untill it says Done.
The procedure take about 2 minutes.
