Has key got dot on blade
2002 Daihatsu Terios 1.3 16V
hi
I have a problem with this car. It has immo problems and will not start. the car works 3 seconds and shuts down after it.
the car was stopped a long time without battery.
someone has some way to get back to work?
ecu is denso
89560-87423
112000-9470
in ecu I see 93c56
immo box
89702-87408 89780-87403
626032-00.
in immo box I see 93lc66.
can u read the key data then i will put the data into the immo file and repost
this seems to be a 4d key
Hello
Having examined your request, file seems OK and key data belong to it.Seems other problems.
In fact, it may need Resynchronization between Immo ECU and engine control ECU as it is sometimes the case when the battery is removed and the keep alive Memory of the ECU is not more supply with electrical energy.
Find out an EOM tool for DAIHATSU and try Synchro
Best Regards
today,i test with launch x-431,but dont option to synchronize.
and see error P1601 Keyless communication(code disaccordi communication error)
Those immo box have many faults with tranponder driver I.C.
Did anyone manage to make immo off?
I have sam problem
is the immo box a new one ? this happen if the ecu dont match the immo box ,
cj
No. IMMO box and ECU is original, customer lost key. I need to make immo off. But i need dumps or something
Dihatsu is just another Toyota and looks like you may just have to resync the PCM to the Immob ecu buy grounding pin 13 on you Diagnostic conector for 31 min and key on. make sure you have a good batt or conect a power supply to your battery. after 31 min trun off key and disconect the ground jummper and see if the car starts.
dear
can cont pin 4 and pin13
hi , i have same problem whit terios 1.0 car start for 3 second after stop, i need help for look my dump. regard alex
this is key
7E CE 8E 95 C0 00 00 00 00 B2 2C 7E 00 00
TIRIS
7E 73 71 A9 03 00 00 00 00 4D 34 7E 00 00
jorgesecurity (22nd March, 2021)
