Page 1 of 3 123 LastLast
Results 1 to 15 of 43
    DK Veteran elchip's Avatar
    EU
    Wink IBM T41 T42 RS232 output trick
    Hello to all member's of DK.
    After I need RS232 for autodiagnostic and haven't it on my IBM T42 I was look for tipe hov to output it without docking station... And I was spend a lot time tofind schematic diagram of T41 , T42 Apolo 9 mainboard ( Apolo 9 is code name for MB on T41 and T42 ).
    Here is what you need :
    For all who need COM1 on IBM T41 and T42 it can be put out from Mainboard of laptop.
    Look for MAX3243C on MB. It is RS232 transceiver located on MB but it's I/O are
    only on dock station connector ( 245 pin HUH...).
    I was success output direct from MAX3243C COM1 with cable and work 100%.
    U need good solder and time and magnifier too ;-)
    Here are PDF files of MAX3243C and laptop schematic of RS232 COM1.
    ALso you need to enable COM1 in BIOS setup.
    The chip MAX3243C is located on MB bottom on memory socket inside laptop.
    You must remove keyboard and inside memory module.
    Better disasemble MB of laptop ( if you have time and know to do that...).
    IBM T41 T42 RS232 transceiver sch.pdf
    MAX3243C datasheet.pdf
    If you find is good for you please push THANKS .
    Sorry for my bad English.
    Best regards to all on DK
  2. The Following 15 Users Say Thank You to elchip For This Useful Post:
    123qwe123qwe (9th October, 2019), AlexBrown (7th November, 2015), arasss1979 (7th July, 2018), Bazil_mb (8th December, 2013), bigoneoszi (27th April, 2017), fdyg (4th February, 2017), florinssl (3rd May, 2020), frasenci (14th October, 2013), hani93 (7th May, 2013), ker0sin (18th September, 2014), obetbalguest (17th May, 2013), robika (7th December, 2013), welaegea (8th July, 2013), wice (24th June, 2013), yasser (8th September, 2014)
  3. #2
    Default BIOS settings Dell D620 or D830
    I know there are some Dell D620 with Mercedes Stardiagnosis for sell. I have installed Stardiagnosis on my Dell D830. It has a RS232 com port but I cant't get it to work. Is there anybody here maybe that knows the right port setting that need to be done in the Bios ?
    Any help is more than welcome
    wiseman's Avatar
    I have an IBM x41 but have docking station, very interesting read
    Hi, Elchip !
    Is the same MAX chip on the X31 tablet's motherboard ?
    I can't find it's schematic. Thanks in advance.
    Nov 2010
    Quote Originally Posted by wiseman View Post
    X41/X41 Tablet has the RS232 chip in the Ultrabase, not in the laptop like T4x series.
    BTW, elchip do you have a photo of the finished soldering on the MAX3243 chip?
    Mar 2012
    Hello i've got MIOZ3 GPS module and I was searching everywhere for thinkpad pinouts to make internal GPS over COM port.
    Good job, thank you.
    Junior Member vionet's Avatar
    France, Paris
    Default rs323
    Quote Originally Posted by Raceboy View Post
    Hi, it's working in my laptop.
  9. The Following 2 Users Say Thank You to vionet For This Useful Post:
    arasss1979 (7th July, 2018), bigoneoszi (27th April, 2017)
  10. #8
    Jan 2013
    elchip: thank you very much, good job.
  11. #9
    Jan 2013
    What Is the battery life with docking station?
  12. #10
    Mar 2013
  13. #11
    Mar 2013
    Nice hack
    i will try it this week
    i need it for car diagnostic
  14. #12
    Jun 2013
    i need for cardiagnostic too
    but i cant understand on what pin i have to solder wires of rs232 connector and on chip ,can anuone help me? sorry on bad english
  15. #13
    Mar 2014
    Burnaby Canada
    As the pic shows, there are a bunch of solder pads next to the MAX3243.
    This is a pic of a T43P.
    The centre hand made drawing is the pinout between the com connector and the solder pads.
    [3]TXD is pin 11 of MAX3243
    [8]CTS is pin 6 of MAX
    [7]RTS is pin 10 of MAX
    [2]RXD is pin 8 of MAX
  16. #14
    Mar 2014
    Europe
    Hello
    Really good idea!
    I've question to whose who ha done the following upgrade.
    Have you routed all 9 wires? Or only couple of them?
    Thanks.
  17. #15
    Mar 2014
    Burnaby Canada
    Here is all 8 plus a ground. It would be difficult to route a 9 connector shielded cable inside a T43.
    Seems a few have used TX, RX, and ground. I havent tried this mod.
  18. The Following User Says Thank You to malch For This Useful Post:
