Page 3 of 10 FirstFirst 12345678 ... LastLast
Results 31 to 45 of 148
  1. #31
    Jun 2009
    Quote Originally Posted by amaflo View Post
    I read again back pcb 24c16 the st-6000 V125.52.
    please activate.
    I read wrong the first time.
    I read again back pcb 24c16.
    can someone help me?
    st-6000 to update 128 is activated?
    thanks.
  2. #32
    Milky Way
    thanks.
    You have version 75 activated...
    Here is your file updated:
  3. #33
    helmi reguig's Avatar
    May 2011
    altamura bari it
    Default brain bee st6000
    mes amies je veux savoire eprom 24c16 dans multiplexer 2
    ou dans st6000 voila ou jais trouve un eprom 24c16 voir image
    je cherche ou se mette le fichier dans eprom merci
    aides moi jais v56
    I want my friends savoire eprom 24C16 in two multiplex
    ST6000 or veiled or jet is a 24C16 EPROM see image
    I'm looking for the file or put in EPROM thank you
    aid me jet v56
  4. #34
    Milky Way
    Quote Originally Posted by helmi reguig View Post
    aides moi jais v56
    aid me jet v56
    As i told you by pm, on the ST6000 thera are two 24C16 (don't touch on the multiplexer). To have access to the correct eeprom, you need to disassemble the tool complety, removing the lcd and the main board. On the back side of the main board, there is a small module (similar to the one on the front) with another 24C16. That's the one you should read.
  5. The Following User Says Thank You to LuisAndre For This Useful Post:
    helmi reguig (22nd June, 2016)
  6. #35
    May 2009
    Default Help to activate
    Hi please help me ...
    here my original 24c16.
  7. #36
    May 2009
    I was wrong to read, this is the correct eprom 24c16,
    back side of the main board.
    thanks in advance.
  8. #37
    Milky Way
    Quote Originally Posted by gcesare21 View Post
    thanks in advance.
    Here you go m8:
  9. #38
    May 2009
    Quote Originally Posted by LuisAndre View Post
    Here you go m8:
    Work OK !!!
    THANKS !!!
    you are great.
    possible to know how do you calculate cecksum ?
  10. #39
    Is a great work of LuisAndre.
    i don't know that bytes compute with the checksum but i think that there're two blocks and the blocks have two checksums
    The first block start at address $500 ?? the first checksum of this block at addres $5F0 and the second at $5F4
    The second block start at address $600 ?? the first checksum of this block at address $6F0 and the second at $6F4, this block don't work with the updates...
    The checksum is possible that be of 32 bits but that algo ??
    The question is, for the checksum the compute of bytes start at $500 to $5F0 for the two checksums and what algo?
    Is a great work LuisAndre
    excuse me my english...
  11. #40
    somewhere
    Hi.
    I would like change bb6000 version to 125, and active all cars, and trucks, and multiplexer2! I change the original to 106 only car, and works fine, but the chechsum is not ok!
    Anyone help me?
    Thanks!
    Regards!
  12. #41
    please luis unlock my brainbee.....thanks
  13. #42
    Hi!
    I can update V255
    W PM.
    BR
  14. #43
    Default ST600 UPDATE
    Can help me to update my Brain Bee ST6000 to the new version, My version only Cars and Vans, I would like to unloock the tool to get trucks list available.
    Many thanks.........
  15. #44
    Hi.
    Please mod to new version car and trucks my st6000
    Thank you!
    Regards!
  16. #45
    Smile
    LuisAndre help please
