Page 5 of 6 FirstFirst 123456 LastLast
Results 61 to 75 of 80
  1. #61
    100% working dump pic12ce519 with the Chinese clone.
  2. The Following 6 Users Say Thank You to EduardNN For This Useful Post:
    andrius (23rd January, 2014), Col19 (17th November, 2019), Maik67 (24th July, 2016), proka (31st January, 2014), shtyrya2 (26th September, 2015), Tom V (8th April, 2020)
  3. #62
    tehnosoftex's Avatar
    Romania
    Quote Originally Posted by EduardNN View Post
    But this one is banned in 2011 versions of xentry. It worth to try to combine the dump from bigovic and the dump from you.
  4. The Following User Says Thank You to tehnosoftex For This Useful Post:
  5. #63
    DK Veteran dimitar22's Avatar
    Jan 2009
    Hello
    I have one question is it possible to use my cardaq plus interface with das or Xentury software in order to diagnose MB trucks?
    Cables are not problems i have pinout from interface and truck.
    How to configure software to recognize this interface?
    You can see the interface here
    CarDAQ Plus
  6. #64
    Sep 2010
    More thanks
  7. The Following User Says Thank You to Gregor30 For This Useful Post:
  8. #65
    Is this for D3 or D4 Mux?
  9. #66
    Quote Originally Posted by tehnosoftex View Post
    I pointed out where that is in the dump.
    Change the number to any which want!
    For my bad English - scold GOOGLE translator...
    Don`t forget to use
    Thanks button and reputation
  10. #67
    Jan 2012
    hello . for C4 MUX not fiind solution ? dump
  11. #68
    Quote Originally Posted by AlbertM View Post
    C4 multiplexer dos not exist.
    Maybe you dreaming for SDconnect dump.
  12. #69
    Aug 2011
    is there any difference in dumps pic12c509A and pic12ce519?
  13. #70
    Aug 2011
    maybe someone has the above full dump for share? many thanks or any other full dump? i have damaged mine
  14. #71
    Aug 2011
    no one has it ?
  15. #72
    Hi which cable use to connect the original multiplexer c3 to laptop dell d630 (com ) , maybe someone has a diagram of such a cable ?
  16. #73
    Jul 2016
    Hello!
    I want to change the serial number
    I read my dump
    I recorded a new 12C509A
    programmer writes all ok
    C3 test fails
    returns the old 12С509A
    test ok
    in the dump did not change
    what is the problem
    help
  17. #74
    Jul 2016
    Thank you! Mr "Bigovic", and all the participants of the forum PIC12CE519 firmware after processing works with PIC12C509A
  18. #75
    Germany
    Cool
    Hallo
    This is Dump from Reseller for Vediamo .
    PIC 12C509
    PIC12C509.zip
    for C3
    And this is from old working C3
    Pic12.zip
  19. The Following 4 Users Say Thank You to ELMACHT For This Useful Post:
    blueberrycheesc (19th September, 2020), chanodaniels (31st July, 2017), Col19 (17th November, 2019), gopelhu (8th February, 2017)
