every clone I know doesn't pass that self test
don't take in head that fact
I tried it again and got the samething,but at 52. The version is HIMDB V1.3a when I click F12 on HDS. I think I'm going to buy another one. It sucks. Because this one still scans all systems and reflash pcm's. Just won't do keys or register pcm. I see them on ebay for under $200. I paid over $400. four years ago. They have come down. Have you or anyone else use there Ford vcm on Honda and have no problem reflashing it back for Ford stuff. Aka going back and forth with it. I hate to use it,because it will not ever expire for ford updates.
HIMDB 1.3a is related to 2.021 version, try to flash the HIM via early version of HDS via 'Progam the HIM' button and see what HIMDB version will be shown after programing.
p.s. It could be that downgrade of HDS internal software is prohobited, didn't check myself.
if buy Ford VCM and are going to use with Honda you probably will be stuck with HDS version 2.016 as special patched version of boot/flash image is required.
I think that your Honda HIM is working perfectly and you won't get anything better for 200$
im having same problem with honda gna 600 ad robbyd was with his HIM.it would work on every thing excepts immo,can,t change pcm,add key etc im now atcounter41.and using lates ver 2.21.i tried to use a year old ver but no luck i did try to reflash it no help this is orginal gna 600 but with no subscribe with honda, cant call honda.key code generter give me the same password that wont work,can anybody help me how to unlock immo opion thanks
do not use honda/acura generator for 1st password, it's always wrong, see yourself - try any date and VIN - it's lways the same - that is invalid for current algorithm
just use - all keys lost
in that case you only need PCM code which you can generate correctly.
p.s. never try more than 3 wrong attempts it's senseless as you are using probably wrong tool. Your HIM/GNA600 will be locked if you'll continue more and more times unsuccessfully.
Every time I reflash Him it reads different version. So it's taking flash. The last one I tried was 2.018.013 the version was 1.2a. I'm going to get new unit to try. I can't waste time and lose cars like this. It's kind of making me look bad when I go back and forth to vehicle to try this or that at customer's shop. Once I get new one I'll let you's now if that was the problem or not. Thanks for all help. Rob
AS i have ford vcm clone i try to use it on hds all function works but not communication with immo, then i usa the gna 600 on ford it update the code and all function good on ford vehicles,then i reused it on hds it ask me to program the him i did ,all function good but immo is still locked asking for 5 digt pin from iN honda .can someone help me plz with it
Cklair. Your going to have to change your Key generator. Or at least change date on your computer to year 2008 and try. This Thanks go's out to all that helped. Thank you for the help. It worked on one vehicle. Will try on other Monday. I don't need another tool after all. Thank You again. Just one thing. Where can I get that key generator from.
yes i unlocked the hds immo with the help of very genius DK member,he is the man,have no words to say thanks to him, great guy and help full thanks for your time
you've just got
what the doctor was ordered
drdupery. Thanks. I was just ready to buy another one but it turned out to be Key code generator problem.
only two digits from date are used in formula so you even can shuffle more and more and sometimes you'll be getting correct result
for example try month 10-12 and probably you'll get wrong result using your method
