Yes you are right
I just wanted to post that if you are having trouble getting the pin code for the Immo it's caused by the date you need to input. It says to input the date this way( MMDDYY ) but you need to enter it this way ( YYDDMM ) and you will get the right pin. I only by chance tried it that way cause i didn't know what to do. Wasted half a day till i got it to work.
Yes you are right
What date do you put in ? Is it the date the car was first registered?
Cheers
many thanks for clearing that issue up
best regards
Hey. Does anyone know how to reset the attempt counter for HDS. I'm at 36 and the key generator only goes to 25. I'm having problem with last couple vehicles. I just reinstalled HDS to see if that will do it. Or is it the pcm that's doing it.
in fact, the format is correct MMDDYY
just input 00 onstead of 10 for year 2010
there are some conclusions analyzing internal structures of HDS 2.021
the locked status due to many times passwords were entered incorrectly is stored in HIM, the times the 1st password are used is stored also in HIM, that prevents from using same date for every use.
you could try to return to early version of HDS in order to program HIM with old version that probably will help to clear internal stored flags directly in your HIM
So drdupery, your saying if I go back to one of those two and reload it and reflash him to it that will reset counter. And can I go back to version 2.021.008. Or will it screw it up again? I tried to remove and reinstall 2.021 but that didn't help. It just picked up where it left off with 38 on counter. Also do I need to remove the key generator or will it be alright. When I installed it with Winhex I don't know what version of HDS I was using at the time. I just kept updating HDS as I got it..I just throught as long as it's unlocked (key gen)to use it's.it's ok. I will try an earlier version of HDS. Thanks
What version of HDS are you using?
The status of immo functions locked or not is stored in HIM so reinstalling HDS won't help.
Flashing the HIM probably will help to clear stored values in HIM.
The HDS didn't depends on generator so you haven't to remove generator.
Try to use early version of HDS you'll find, it will be good to use version before 2.015 (HIM DB version 1.0x)
I did. It did not work. I'm at count 50. I went as far as 2.002 I think. I reflashed twice. Once with it pluged in outlet and then with vehicle connected. Think the Him just went bad?? It reads any and all codes ,other modules and stuff like that. Just won't do keys or reset pcm. Just won't reset counter back to zero. Hell ,anything below 25 would be great right now.I removed all of HDS on computer,ran couple clean upsoftware too. And ran ford ids cleanup software everytime I tried loading earlier HDS. Still the same thing, counter not resetting. Please any and all HELP would be GREAT!!
bad news...
what version shows Interface Device Software (if you press in HDS F12 key) ?
You could try to use another computer in case attempt counter also was stored at computer.
p.s. and remember it seems that honda generator generates incorrectly 1st pass.
