Page 4 of 4 FirstFirst 1234
Results 46 to 60 of 60
  1. #46
    Jun 2011
    Sorry to open up an old thread but didnt want to create a new post if not necessary,
    I have a honda accord 2003, with hds him with double board, am running hds v3.017.012 i have read keys in vehicle and there are 2 stored, i want to delete key 2 or if easier as it seems delete all keys then use pcm code to program one key, also i have a second key with immobiliser chip can that be programmed to this so that vehicle can start with that key as well ?
    Thanks in advance.
  2. #47
    magneto21's Avatar
    Jul 2016
    use the option all key lost,and you can program any key you want-of course has to be for the same model of your car.
    Is simple and you will not lock your him-as long you generate proper pcm password.
    regards,
  3. #48
    DK Veteran buga37's Avatar
    Apr 2010
    USA
    Quote Originally Posted by sajeel1978 View Post
    Thanks in advance.
    as far as i know there is no PCM calc that will work with this version of HDS. I'm using 3.08 version, works good
  4. #49
    Jun 2011
    Quote Originally Posted by buga37 View Post
    Thanks for replies, can i install 3.08 alongside other version, also i dont have pcm calc software which one do you use ?
  5. #50
    Apr 2010
    USA
    You will have to remove newer version that you have. Just search for it online, i can't post any links here
  6. #51
    Nov 2016
    Rio das Ostras, Brazil
    Where I find HondaAcurra.exe?
  7. #52
    Dec 2017
    Quote Originally Posted by lgrebello View Post
    I've been looking too.. but I found a patch for HDS that will let you unlock your him if you locked it up. It came from a russian forum and changes the date + patches HDS.
  8. The Following 3 Users Say Thank You to bashfull For This Useful Post:
    hbalazs (6th February, 2018), jomo671 (13th December, 2017), uu161 (4th March, 2018)
  9. #53
    Dec 2017
    Quote Originally Posted by bashfull View Post
    Thanks. What is the password to access the contents of the .rar file?
  10. #54
    Nov 2020
    Quote Originally Posted by yellowstilo View Post
    here you go....
  11. #55
    Apr 2017
  12. #56
    Jun 2021
    Home
    how to use it ??
  13. #57
    May 2022
    Hey guys, thanks to all of the info in this thread I was able to get my new key registered on a 2008 Honda Civic LX. Thank you! I wanted to summarize what ended up working for me in case it can help someone else out.
    I am using a Windows 10 64bit laptop with HDS HIM version V3.104.24
    I also downloaded the honda key code generator. If you do a web search for "honda hey code generator 95266", then you should be able to find the one I used. It just spits out the PCM code.
    I manually set the date on my computer to the year 2008.
    I opened the honda key code generator and put in the last 5 digits of my VIN and the current date in the MMDDYY format. My computer was set to May 27th, 2008, so I put in 052708. This gave me the PCM code.
    I initially had the F12 menu in HDS setup to the global version and could not get the Honda key code generator to make a code that would work. I had to switch to the US market to get it all to work.
    Use the lost all keys option in HDS and it will ask you for the PCM code. I put in the code from the generator and it worked. This required me to reregister all of my existing keys along with the new key. After the process was complete, all of my keys worked and the fobs also worked.
    Thanks again to this forum!
  14. The Following User Says Thank You to pole7 For This Useful Post:
    kasper1910 (9th April, 2023)
  15. #58
    Apr 2023
    Try password www.autoprogs.ru
    But i dont understand, how it works.
  16. #59
    Oct 2022
    LDZ
    Did you install only HDS HIM v 3.104.24 or also i-hds and imubilizzer setup tool ??
    I got HDS v3.104.002.
    My problem is that i cannot see in system selection menu "IMMOBI" module, after connection with my Accord 2004... I can open Immobilizer setup tool from main I-HDS launcher, that is autonomic program made by Bosch, but I cannot login to it , because I dont have dealer login and pass.
    can somebody tell me how to get immobi option in HDS. What version is needed. I need to add new key to my Honda
    PS: I got installed HDS, I-HDS and Immobilizer setup tool v. 13.1.0.
    Regards
  17. #60
    Sep 2023
    worked perfectly!
