converter usb serial port to lose data
existe una perdida de datos al convertir el puerto serial a usb esa es una de las dudas tengo algien sabe algo
Please .... use google translate !!
Did you mean:
"Is there a loss of data if you use a serial to usb converter ?"
I don't think so as long as you use a good converter.
It depends on what pins the device uses for steering the dataflow like dts/rts. A good converter supports all ways of dataflow steering.
Biggest problem is to map the cable/converter to the right com port certainly if this com port is already in use by another (on-board) serial port. If you know your way around in windows you can easily solve this problem.
I now have 2 serial to usb converters (one in a cable and one integrated in a device) both mapped on com1:
Connecting them both to my pc is obviously a problem; If I disconnect the first one and connect number 2 I have sometimes driver problems and have to reboot to straighten things out.
Regards,
ITR703
Please consider the Thanks button if my post is usefull
just buy a converter and you ll be fine.
Compra un convertor usb serial..i todo ira bien.
