Try this
*1rrt0ztk24vm1vmsvuxvhhtz3jgwmyobyrw0qaksvt0uw
Good luck!
Please help to get Starkey for 03.2010:
XENTRY
Hw-ID: 577BAE9F2998
AppID: 252
DAS
LanID: 0800381FAE17
Have you copied the modified commonlic.dll in C:\windows\zak\starutils directory?But I paste Xentry key without space and it doesn't accept.
Can you generate it again please
If you have not, do a search on the forum it should be on here
Last edited by impactops; 15th September, 2010 at 02:47 PM. Reason: Spelling correction
hi guys i am totally lost read so much now even more confused. i have also tried the universal key but not working help my hw-id 4E26744d6754 AppID 252, and i am running 03 2010 xentry i am looking for a developer keygen also thanks if anyone can help
yes i have but i moved the exsisting one out first, then pasted the mod one,
i may be getting confused with version no`s. do you mean when you say 3/2010 as in dvd release as i am running v05/2010 (2010-04-15). but my xentry is v6.2.4 program and data is v03/2010
is this where i am making a mistake
correct
if you are using 5.2010 or 7.2010 this key will work
ZRDTG5XSB3FMPP4P2KJYGZKLSMFWH7TCX8CWXYEQDNUTY6SU7L B2MSUF6MA7E6WBTCLSEG7WWPXT4GCL9QAXZG3GL6DG8KQK9HWS 5ZEH5DEUTGWHXK3BGP98KUKQGU52M6GDLQS
but no developer, no need to copy dll across or any other bullshit tool people are saying to use.It is provided by MB themselves on the DVD since the begining.It is also universal so it will work regardless of HWID
Remove Space, No Spaces
Good Luck!
thanks i will try that now, just last question if i activate non developer mode on xentry will i loose my das developer mode on the same hard drive
tried to do it it says the start key is invalid. id of application in start key (250)<> id of selected application (252)
i give up, i cant seem to get xentry to work still getting (2221-29) no access authorization code.
anyone there that can help a dull one thanks
Smart car engineer ,
