Hello
Can anyone calculate for me pass for xentry dev.mode?
HW-ID 58A9FC416A8A
AppId 252
DAS 08000358514A
Thanks in advance
Hello
HW-ID 58A9FC416A8A
AppId 252
DAS 08000358514A
Thanks in advance
I'm using DAS 04/2008
I want but I don't have courage to do this. I have an original diagnostic head and I'm a little bit affraid to use newer version. Is it possible to generate this code fo my version or do I have to make an update?
I do not quite know if the keys work for such an older version, but you can try !!
However if you decide to upgrade to 2010.01 or 2010.03 they will work. The DAS key will also work with 2010.07
DAS Developer : *1srt0ztk24vm0nhnhdxvhhtz3jhwm4obyxuwqij0vqpsy
Xentry Normal : NYNG2V5JHHMC296K4HB8XV2HT4C9QMDFQR3XT4H8NWEYDVUHVY KCNM8JKRPDNS7R7SNYYCAM3DYZNLLUVTDRK23TTSW4WCQYAUC2 QDPZR3ELYVJG4V2TWRR2ZBHKF73RFE
To instal 2010.01 or .03 do follow the Zolookas guide step by step. You will not have any problems.
http://www.digital-kaos.co.uk/forums...n-full-158492/
Try, enjoy and report back !!
G.
thanks i will try that now, just last question if i activate non developer mode on xentry will i loose my das developer mode on the same hard drivetried to do it it says the start key is invalid. id of application in start key (250)<> id of selected application (252)Unfortunatley mate you are asking questions at a time where the part of the forum that had all the answers is not accessable anymore.The key request thread is exactly that key reqeuest not problem request.You have had ample time to get this going considering your join date is jan 2010.i give up, i cant seem to get xentry to work still getting (2221-29) no access authorization code.
anyone there that can help a dull one thanks
You need too change the registry key from compact4 to compact2 to get it change the appid to 250 so that the key i posted is accepted.
That's it from me, i wish you all the best.
Hello!
Can some one generate XENTRY dev KEY 07/2010 FOR THIS
XENTRY :
AppID 250
HW-ID : 020509AEFD7F
Your joking right???????
1st post join date oct 2009 & your asking for 7.2010 dev key.It means you didn't bother to read to software section when it was available & you haven't read any of the current posts regarding this.
Unless you have just come out of a coma i would ban you if i was in charge, it's a good thing that i am not!!
AppID 252
HW-ID : 46c8e2b9fd51
Xentry key ?
Best regards
Life ain't forgiven & forgiven ain't free
no Soul will rest, while hunter run free ....
