Page 1 of 3 123 LastLast
Results 1 to 15 of 35
    BestElectrical's Avatar
    Feb 2010
    San Diego, CA, USA
    Default Orange5 Clone problem , Dead Orange5
    Hello, Did anybody encounter this issue.
    I have both Orange5, Clone and Original.
    I accidentally opened Orange5 original while my clone was connected.
    Software opened up and said that it is setting up new software.... after that finished, the orange5 clone is no longer visible when plugged in to usb. It does not show any type of life.
    Any info on recovery will be greatly appreciated.
    Thank you!
  2. The Following User Says Thank You to BestElectrical For This Useful Post:
    electronicscars (1st October, 2018)
  3. #2
    Sep 2009
    found any solution i have same problem????
    Jun 2013
    PANDO, URUGUAY!!!
    Hello everyone, I have connections to read an ATMEGA AT91SAM7X256 DE ORANGE5 BOARD but if the processor is locked at the factory can not read the file, first you have to put the erased pin to ground to clear the chip and unlock and then you will have the whole chip in FF and unlocked, we need a good firmware file, but I do not know how to get it since I try to read an orange5 in operation but it is blocked
  5. The Following 8 Users Say Thank You to electronicscars For This Useful Post:
    abderrahmane17 (28th November, 2022), auto421 (1st December, 2023), dij16 (8th April, 2022), klonone (5th January, 2023), lostking2008 (28th December, 2021), masafaga (29th September, 2022), mexanico1971 (14th August, 2021), Troco5773 (17th December, 2022)
  6. #4
    Sep 2018
    Hello dear.. did you find any solution? I have same problem..
    Electronicscars. Your post is very helpfull. Thanks
  7. #5
    Jun 2013
    PANDO, URUGUAY!!!
    hi people, i reopen thiss post to ask if anyone have the internal file for the atmega of thiss orange5 for repair .... thanksyou
  8. #6
    Apr 2017
    i have the same problem.. pls share any solution
  9. #7
    Nov 2018
    Hi guys , I'm having the same issue ...please help
  10. #8
    Jan 2019
    Somewhere between Continents
    hello guys...
    I have some Orange5 bin files (i think its the firmwre but not sure what serial and how wil it work...
    Anyone knows how to get SAM-BA to work with Orange5 PCB?
    I also want to do some testing but i dont have the Jtag Programmer and for what i read, it seems to be possible to use SAM-BA app from Atmel to load firmware on this by USB...
    Just Consider helping Freely like I want to do...
    Thanks and Rep are Always Welcome...
  11. The Following 2 Users Say Thank You to boxsport For This Useful Post:
    lostking2008 (28th December, 2021), Raffy haddad (3rd August, 2022)
  12. #9
    Feb 2021
    Hi Boxsport,
    I'm also having the same issue of killed Orange5 clone v1.34. Can you share the bin file you have?
    For how to use sam-ba, there is a youtube video FYI:
    https://www.youtube.com/watch?v=HsLmJtrzsnE
    Using the AT91SAM7S SAM-BA on-chip bootloader and the SAM-BA in-system programming software to load firmware to the AT91SAM7S256 microcontroller via the USB port. Read the tutorial at: http://startingelectronics.org/tutori... No external programmer is needed, the firmware is loaded to the microcontroller's Flash memory from the USB port using the SAM-BA in-system programming software that is available for free from Atmel. The tutorial at the above link contains more information about the hardware and where to download the SAM-BA software from.
    #3 post also looks interesting.
    Hardware Requirements:
    In order for the boot loader to work, there are some hardware requirements that must be met on the microcontroller circuit:
    • The USB microcontroller pins must be connected to a USB connector.
    • An 18.432 MHz crystal must be used for the microcontroller oscillator to enable a 40MHZ clock for USB operation.
    • Pin PIOA16 (PA16) must be dedicated to switching on the USB pull-up resistor - usually through a transistor.
    • The TST pin needs to be connected to a jumper to be able to pull it high.
    • Pins PA0, PA1 and PA2 must all be pulled high when the TST pin is pulled high.
    Thanks,
    Ken
  13. The Following User Says Thank You to lostking2008 For This Useful Post:
    boxsport (29th December, 2021)
  14. #10
    Jan 2019
    Quote Originally Posted by lostking2008 View Post
    Hi Boxsport,
    Thanks,
    Ken
    Hello there...
    Yes i can share the files i have...
    Send me PM and we will speak...
    I will check the info you shared when i have some time because i´m very busy with work at the moment but i will save the info to check in some free time...
    thanks...
    Cheers
  15. The Following 3 Users Say Thank You to boxsport For This Useful Post:
    loki954 (23rd July, 2022), lostking2008 (29th December, 2021), Troco5773 (12th October, 2023)
  16. #11
    Feb 2021
    Hi Boxsport, PM sent. Thanks, Ken
  17. The Following User Says Thank You to lostking2008 For This Useful Post:
  18. #12
    Apr 2022
    Default Orange 5
    Hello i need dump for mcu orange 5 programer
  19. #13
    Aug 2016
    Swindon
    Hi Boxsport, PM sent. Thanks, Mac
  20. #14
    Apr 2015
    Did you manage to erase and identify with jlink ?
    If yes maybe.procedure of howand settings in jlink will help is and ease the job for me and others
  21. #15
    Apr 2015
    Thanks to boxsport but these file are not to 05 fw they are files of 192kb wich I loaded and nothing happen
    and these 2 files called fw are same as flash flash 2 in soft V1.36 in folder called same lx570
