DAS And XENTRY DEV KEY REQUEST
Page 1 of 332 1234561151101 ... LastLast
Results 1 to 15 of 4978
    chakahafed's Avatar
    nouakchott
    Default DAS And XENTRY DEV KEY REQUEST
    Das Xentry Requesting keys
  2. The Following 5 Users Say Thank You to chakahafed For This Useful Post:
    achraf11 (27th March, 2015), dingchavaz (29th September, 2016), gasa (17th February, 2020), irazouk (16th July, 2018)
  3. #2
    ITALIAN
    Quote Originally Posted by chakahafed View Post
    Can some one generate DAS and XENTRY dev KEY 03/2010 FOR THIS lan id DAS:
    08000186BC88
    XENTRY :
    AppID 252
    HW-ID : 4F307B4E7C98
    Best regards
    xentry :
    2QP6VNFRN6R5TQEHQ69UDAU6223KVSM3YKH85F68BHL85SLZUPJLGYNFHKAGGLHVK6NSNB7MNC6SPPAH6FJ5A3F3QVJY7TL7Z4RFNYPDUESP5XDJBPTBTGF8F2HTTA8P6W
    Das Dev:*1rr50ztk24vm0300lfxvhhtz3jgkmzrryqu0pdl0vtijw
    Don't forget to thank when someone helps you!
    Australia
    Hi Guys,
    Can someone genetate a XENTRY dev KEY 03/2010 for lan id
    Xentry HW-ID:
    6C72E79E44AC
    AppId:
    253
    chakahafed's Avatar
    nouakchott
    Angry error 2221-29
    Worked for das DAS DEV
    I CANT RUN XENTRY ANY MORE I HAVE THIS ERROR 2221-29
    IN ATACHED PIC
    Junior Member brumetw's Avatar
    Quote Originally Posted by mob380sec View Post
    Hi Guys,
    Xentry HW-ID:
    6C72E79E44AC
    AppId:
    253
    try this
    877KTVQ49KVC2C4B555GGELT7HCN92WAY69K65L6KY3Y797K24YB9YDK9NT5XCEAJFKFXARRY2R6L7SX5PUE2SJVCNC2MT8VK2N2GJRFU5LVK8APM247S5TQR32C9P3RRA
    DK Veteran strda50es's Avatar
    Belgrade
    IN ATACHED PIC
    Hi mate.
    Are you sure you've change the two more files needed except the key and the commonlic file?
    All good things come to those who wait....
    chakahafed's Avatar
    nouakchott
    [QUOTE=strda50es;739699]Hi mate.
    Are you sure you've change the two more files needed except the key and the commonlic file?[/QUOTE
    WHAT TO MORE FILES ??
    I CHANGED COMMONLIC.DLL
    AND COM.DCX.LICENCESUPPORT.JAR
    AND COMONLIC.DLL IN Frogram/xentry/bin/dll.
    yesterday xntry worked fine but today i have this error!!
  10. #9
    DK Veteran cocutanu's Avatar
    Jun 2009
    What version you have installed ?
    I'm afraid you will need Xentry timeout fix. Your Xentry is expired.
    BR
  11. #10
    chakahafed's Avatar
    nouakchott
    i dont think !! das ver 03 2010
    any way i have just applied the time fix with no result
    i think i have to make fresh installation another time
  12. #11
    Oct 2008
    Greece
    Exclamation
    Well, I am still here.....
    Now.....
    Because i think you Upgraded your WIS/ASRA or something like that, Re-install ONLY Xentry 3.2010
    and replace again the files as you know when installation finish.....
    Also, FOR SURE you need to use the Timeout Fix for to run Xentry!!!
    Good Luck!
    Regards!
  13. #12
    [quote=chakahafed;739768]
    Quote Originally Posted by strda50es View Post
    Hi mate.
    You can delete the COMMONLIC.DLL under the c:\windows\system32\ and you Xentry will work again
  14. #13
    Jun 2009
    I was just guessing your problem...didn't know what version you are using. So..check what Patrian said but before of that go back to StarUtilities and check if you still have a valid key inside Xentry field...try to save that one again. About the Xentry timeout fix...there are few versions of that...some of those require to back up your system date and apply the fix. But first of all try what tkinyan said...this will be the easy way..if it is working.
    Good Luck
  15. #14
    080097DF038F
    XENTRY :
    AppID 252
    HW-ID : 599F6E8AE64B
  16. #15
    i have DAS 8/2008. can someone walk me through how to enable DEV? thanks
