Page 12 of 12 FirstFirst ... 2789101112
Results 166 to 175 of 175
  1. #166
    Mine was 1.59, I back flashed it to 1.45 and now it doesnt work. OPCOM SW reads it but it doesnt connect to car. Also, OCFLASH can read current FW version, but refuses to flash it back to 1.59. Is there a solution?
  2. #167
    Dec 2012
    solution depends on what pic mcu inside it
  3. #168
    Its : PIC18F458
  4. #169
    Dec 2016
    I have an 201008 China Clone Op-com interface. This worked fine until I did a firmware update to 1.59. Now, when I connect it to my car and try to open Op-Com China Clone software, my car open herself headlights and increases its engine speed. I tried to revert to a lower firmware version (1.39), but OCFlash says that "Bootloader did not respond...either killed interface, empty pic or new protection!" If I try to write only the bootloader everything are written right, but there are still 1.59 firmware version.
    What should I do next?
    Thank you!
  5. #170
    It's probably fake PIC inside...so, there's nothing you can do except change PIC with original one
  6. #171
    Apr 2017
    Hi guys,
    I've got this opcom: https://drive.google.com/open?id=0B4...011bWpRenBHUlU
    Tried to use it, but to no avail. It was with 1.59 initially. I downgraded to 1.45, but again no luck.
    No unfortunately, I cannot flash it back to 1.59 it gives me the "bootloader did not respond either killed interface..." error.
    Here is how it looks like with opcomfue
    How can I determine if the pic is empty? And any advices how to flash it again with 1.59?
  7. #172
    Member kingarthas's Avatar
    Nov 2012
    Quote Originally Posted by checho85 View Post
    Hi guys,
    FW updates works for those in which a chip is PIC18F458, and those who have written on the chip OP-COM ? you can stop reading.
  8. #173
    Oct 2017
    hi all is this thread still going and does really work as ive recently fried my clone opcom no bootloader or firmware after using latest software
  9. #174
    May 2018
    hello friend
    you have solution for used opcom china 2014 with 2015 software or 2016 vauxcom? thks
  10. #175
    Jun 2018
    I have make this solution, but not working:
