Hi! Does anybody know what the difference is between OP-COM Revision A, B, C, D? Can the new version of op-com read pin code and change millage on Opel Vectra C?
what will I write into the pic? where do i can download the original content?
After i used the official opcom application, opcomfut don't flash firmware.
the program this writes:
Description: OP-COM USB V2
FTDI USB Serial: FTTL2W97
FTDI-ChipID ChipID: 0xDC5D34D5
FTDI-ChipID Location ID: 0x213
O***M Serial-Number (calculated): IM8WK7VU
O***M FW UPdate Code (calculated): 6LWWIVCV
Interface opened. Handle: 84478784
Baudrate 500kBit/s
Dataformat 8N1
Flowcontrol NONE
SetChars
Timeout 5 seconds
Set DTR and RTS Low = PIC Reset
DTR low
RTS low
Wait 1 second for reset
Set RTS High = PIC running
RTS high
Wait 1.5 second, so bootloader can start FW...
RX Buffer clear... OK
FW Versions- and Interface ID- request send.
Timeout - is your PIC empty? No Firmware?
Set RTS to LOW = PIC Reset
RTS low
What can i do?
Irvine
Hi, some time ago there was a "non upgradable" firmware posted on this forum used to testing 100315e Version without risks.
Anyone have it yet?
Simple.. your JDM doesn't program the PIC!
Ic-prog first write and after verify the programmed code.. so, during the verify, on the first address (000000h) you get that error!
opcom help the bootloader hex file
I used jdm programmer and WinPic800. First i connected programmer to 5 pins on pic and got an error when i tried to upload hex. Don't remember if it was 000000h. But then i connected ground and 12V to the car interface on OP-COM and programming finished succesfully.
or you can use for reprogram the PIC - ICD2, ICD3 tool from Microchip.
MPLAB ICD 2
br
Hi all, think I have just killed my op-com by running 100315e, to confirm, will I need a PIC hardware programmer to reflash the PIC? any help very much appreciated for hardware and software reconmendations.
PIC programmmers is much,simple is JDM based, and complex for proffi.
If there is a need programming PIC controllers in the future by USB and easy to use may be purchas PICKIT2 or 3.
Hello, i will download the fix to see if i can fix my clone or not. if i have any problems i will ask for help
Hi Guys, I bought an opcom and it don't work. I tried opcomfut and got this.... see pics
AUTO ELECTRICIAN, CITY & GUILDS QUALIFIED.
30+ YEARS EXPERIENCE.
OLD SKOOL SPARK
(now retired)
I used newest software of op-com, in clone op-com hardware, now says: "interface test failure".
any idea to fullflash with bootloader of op-com?
thanks.
Hi guys,
Im quite new on forum and i would like to download one of hex files for Op-Com
Done it, that topic helped me a lot. I have programmed OP-COM PIC on board with Willem programmer after i ran newest software and it erased PIC completely. It works well now.
