Thanks guys !!!
Rgds,
C.
Thanks guys !!!
Rgds,
C.
help????????????
Address 03: ABS Brakes (-----) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 AE HW: 1K0 907 379 AE
Component: ESP MK60EC1 H35 0104
Revision: 00H35001
Coding: 000000000000000000000000000000000000
someone could help me to obtain the encoding of the group ABS VW Golf V 1.4 year 2009.
give me yur vin number i send for you the long codig.....
Revision: 00H35001
what your vin in the car i send for you ...... giorgio ????????????????
LONGCODING FOR ASR/ABS MK60EC1/MK70.....IMMOOFF EDC17/MED17/MED9.XX......
Vin number "encrypted" into long coding on most new VAG. Will be required to work.
Hello Guys! Can please someone help me to generate the long coding for ABS/ESP of a VW Vento(Jetta) 2012? I read some posts, i see the VIN is encoded there. A good friend mine tried a different ABS module in the car, and when put back the old one, the coding was erased. So no backup, the problem was a little unexpected.
ABS/ESP: 1k0 907 379 bl / MK60EC1 H31 0152
VIN:3vwdg6168cm101224
If any other info is needed let me now. Thanks in advance! Andrey.
Hello Guys,
I have a customer who is not the brightest and he wanted to put and different cluster into his 2009 golf tdi.
Of course the car wouldn't start but when he put the old cluster back in the car starts but the ABS and traction light is on and flashing.
It has 4 code the 3 sensor calibration and the 4th is the ABS unit coding.
I have calibrated the 3 sensors all codes disappeared but the coding.
When i select coding i get comminication failed on the my AutoBoss v30 when i try to use Gscan i can only input 0s.
Can someone enlight me what's going on. I must say i'm not very expirienced on the VWs but i have coded units in before.
please help me
BALI7605 (3rd November, 2013)
113B200D092200FB880D04E6901D0042310000
