What for? are you replacing the unit?? If so make a dump of the old one first.
car was after acident when repaire it in abs was coding all 0
Go to VW dealer and make coding via VAS online.
Not possible with VCDS.
It is possiblle I think but it is not so easy and best way is by dealer
Only possible if you know the original coding. So if you have a log from the car your are lucky otherwise go to the dealer.
This is a known issue. VAS Tester will go online and check the correct coding in factory database.
Just ask Ross-Tech and you will get the same answer.
Maybe this can help you.
Bope Bravo (6th March, 2015), Mac Gyver (1st June, 2016), Mr16vg60 (2nd January, 2017), proginfo (20th October, 2016), ta79pr (6th October, 2013)
Will not help. Had the same issue on Touran and Scirocco. Tried 30 different codings. Even with same SW/HW Partno.
Not working. Only solution was via VAS. Ross-Tech also suggested to go to dealer.
So don't waste time.
@tachonow
May I get the password for opening the rar.file.
Thanks,
Xaver
I have one giving me trouble right now can I have pass also, maybe it might help me>
Ya..that is what limited in VCDS...We have it but we still refer to VAS or Dealer......
Here is the pass for rar file
(((thi$-i$-the-pa$$word))
Hope the sw will help you. Read all files.
poker (20th August, 2015)
Is it proper password?
I've copied it and then write down and something is wrong. I this this material are legal... Can anyone help me with this?
If I could help just thank...
1K0 907 379 AC ESP FRONT MK60 0101 0021121 00066
03
1K VW Golf Variant 2008 CAXA 1K0 907 379 AC ESP FRONT MK60 0101 0002690 00066
03
1K VW Golf Variant 2008 BSE 1K0 907 379 AC ESP FRONT MK60 0101 0019073 00066
1K VW Golf GT 2008 BLG 1K0 614 517 AC ESP FRONT MK60-AT 0102 0021122 01392 2008-07-18
1K VW Golf Plus 2008 CAXA 1K0 907 379 AC ESP FRONT MK60 0101 0002802 00012 2008-08-15
1K VW Golf V stationcar 2008 BMM 1K0 907 379 AC ESP FRONT MK60 0101 0006786 00066 2009-08-06
