itgate tgc210 no boot
Results 1 to 7 of 7
    Default itgate tgc210 no boot
    Hi fellas,
    My itgate tgc210 is failing to boot up. The LED display is random.
    Tried flashing noboot image using control center but no luck.
    Can anyone help me here?
    Aug 2008
    Wild Mild West
    Have you tried a hard factory reset.
    Turn box off, hold the up arrow on the box, turn box back on, on the on screen menu scroll down to factory reset, push right arrow to select factory reset on the box and that should reset your box to the default settings, i hope that helps.
    plasterer's Avatar
    Jun 2008
    Mersyside
    wot version controll center you useing
    Try the other one
    Then noboot
    Then your image ................Paul
    PAUL
    DK Veteran freck's Avatar
    Jul 2008
    Dark side of the Moon
    Put box in serial mode and flash noboot V6 then uboot V6,I've uploaded them somewhere in here....twice.
    Youll be back on track but on V6,then goto blue panel and flash on V8 or 7.9,your choice.
    Thats the safest and most reliable way,try it on both control centres but the earliest release might be better.
    Freck
    Look here at post#6 by me
    http://www.digital-kaos.co.uk/forums...porary-126453/
    thank you guys for you suggestions.
    but the box is not talking to me or the pc at all. nothing happens when i press the ch+ and on. any more advice ?
    plasterer's Avatar
    Jun 2008
    Mersyside
    Wot happens when you attach the 232 with
    Controll center it must pick the box up......Paul
    PAUL
    hi all,
    sorry couldn't get back to my itgate issue earlier on.. i have tried it again still the same.
    I am using control center 2.5 and usb to serial connector to connect to the box.
    please help i am with the box now now.
