Hello everyone. I was wondering if anyone has seen or have to share a Hitachi program called Dr.zx pc version? Thanks for everyone that replies
I have worked for a time ...with it ....especial litle program to diagonostic hitachis ....
the program is bsaed in palm one and connect to machine with a litle adapter ....especial of this tool ...sopport diagnostics in hitachi?s with issuzu engines ...cilynder test ...delete flash codes ,parameters of engine ...and updates or special keys not needed...
well...in real works usses ..make some diagnostic not supported for service @dvisor of j. deere.....in the newer engines I think is easy to replace with the new idss...only in isuzu engines.
I hope that info help you
I will upload it
cuongnkc12 (17th May, 2016), delta rosso (19th May, 2019), diesel88 (23rd October, 2013), dupisa (21st October, 2014), h311i0n (12th June, 2016), harobaua (14th December, 2017), mijatx (16th December, 2015), PAKBAZ (27th June, 2020), tmtcat (29th August, 2017), yyprins (8th September, 2018)
QUOTE=sattv1244;751694]I will upload it[/QUOTE]
Is this just a palm simulator? Cannot install do to no Lic
DR ZX looks good, but we need a working palm simulator.
Any bites?
I will upload my software from my unit as it looks to be different, sorry doesnt have the plam simulator, it is the actual software I use on my plam.
This software wont do the latest version of machines as you need either WINDR Client version (restricted to read only no changes to ecm) or WINDR dealer.
Hotfile.com: One click file hosting: dataviewer.pdf
Hotfile.com: One click file hosting: windr_download.pdf
Hotfile.com: One click file hosting: WinDr_Installer.pdf
That would be great as i haved used both styles. The PC and palm version but no longer have that program and would like to get it back.
I only had use the palm vercion ....but the pc vercion is used with what kind of adapter????
I forget the name of it. Its just a cable with serial plug and square plug for the fuse box on the hoe.
Deere part number JT07273
Heres are some of the info pdf's for the software for palm DRZX.
Hotfile.com: One click file hosting: Dr-ZX.pdf
Hotfile.com: One click file hosting: Dataviewer.pdf
Hotfile.com: One click file hosting: Install.pdf
dupisa (12th June, 2017)
I tried this download. Can you help with instructions?
It appears as a palm pilot simulator, but cant get lic file.
Also, the dr zx is not there.
which data link use with this software .
