Page 1 of 4 1234 LastLast
Results 1 to 15 of 52
Thread: Hitachi Dr.zx
    Default Hitachi Dr.zx
    Hello everyone. I was wondering if anyone has seen or have to share a Hitachi program called Dr.zx pc version? Thanks for everyone that replies
    DK Veteran hercamp's Avatar
    I have worked for a time ...with it ....especial litle program to diagonostic hitachis ....
    the program is bsaed in palm one and connect to machine with a litle adapter ....especial of this tool ...sopport diagnostics in hitachi?s with issuzu engines ...cilynder test ...delete flash codes ,parameters of engine ...and updates or special keys not needed...
    well...in real works usses ..make some diagnostic not supported for service @dvisor of j. deere.....in the newer engines I think is easy to replace with the new idss...only in isuzu engines.
    I hope that info help you
    DK Veteran sattv1244's Avatar
    I will upload it
  4. The Following 12 Users Say Thank You to sattv1244 For This Useful Post:
    cuongnkc12 (17th May, 2016), delta rosso (19th May, 2019), diesel88 (23rd October, 2013), dupisa (21st October, 2014), h311i0n (12th June, 2016), harobaua (14th December, 2017), mijatx (16th December, 2015), PAKBAZ (27th June, 2020), tmtcat (29th August, 2017), yyprins (8th September, 2018)
    Member fixacar's Avatar
    canada
    That would be great as i haved used both styles. The PC and palm version but no longer have that program and would like to get it back.
    I only had use the palm vercion ....but the pc vercion is used with what kind of adapter????
    canada
    I forget the name of it. Its just a cable with serial plug and square plug for the fuse box on the hoe.
    Deere part number JT07273
  9. The Following User Says Thank You to krichnz For This Useful Post:
    dupisa (12th June, 2017)
  10. #8
    canada
    I tried this download. Can you help with instructions?
    It appears as a palm pilot simulator, but cant get lic file.
    Also, the dr zx is not there.
  11. #9
    Default Dr.zx
    QUOTE=sattv1244;751694]I will upload it[/QUOTE]
    Is this just a palm simulator? Cannot install do to no Lic
  12. #10
    Member 395112801's Avatar
    Quote Originally Posted by sysjay View Post
    Is this just a palm simulator? Cannot install do to no Lic[/QUOTE]
  13. The Following 6 Users Say Thank You to 395112801 For This Useful Post:
    delta rosso (19th May, 2019), dupisa (23rd November, 2013), h311i0n (12th June, 2016), LucasCol (19th July, 2016), tmtcat (29th August, 2017), Zippo1 (18th August, 2019)
  14. #11
    canada
    DR ZX looks good, but we need a working palm simulator.
    Any bites?
  15. #12
    Quote Originally Posted by fixacar View Post
    Any bites?
    I will upload my software from my unit as it looks to be different, sorry doesnt have the plam simulator, it is the actual software I use on my plam.
    This software wont do the latest version of machines as you need either WINDR Client version (restricted to read only no changes to ecm) or WINDR dealer.
    Hotfile.com: One click file hosting: dataviewer.pdf
    Hotfile.com: One click file hosting: windr_download.pdf
    Hotfile.com: One click file hosting: WinDr_Installer.pdf
  16. The Following User Says Thank You to krichnz For This Useful Post:
  17. #13
    Default WINDR dealer
    Would anybody be able to share WINDR dealer???? Thanks Everybody!!!
  18. #14
    canada
    Any palm simulators out here?
    The "PC" file above is palm simulator 5.4 but with no license
    file. I only found garnet 5.4 on-line. I need to find an older version that is still palm.
    Thanks in advance!
  19. #15
  20. The Following 6 Users Say Thank You to 395112801 For This Useful Post:
    andriyan (12th October, 2023), dupisa (12th June, 2017), h311i0n (12th June, 2016), technet (4th November, 2015), tmtcat (29th August, 2017), Zippo1 (18th August, 2019)
