Page 1 of 3 123 LastLast
Results 1 to 15 of 32
    Default QSX15 CM570 service manual & wiring digram
    could any one share cummins QSX15 CM570 service manual & wiring digram this type fettid on generator 500kva and its come with three types ecm :
    1-on engine three connectors ecm.
    2-inside control panal ,four connectors ecm.
    3-inside control panal ,sex connectors ecm.
    thanks in advance.
  2. The Following User Says Thank You to hanzem evr For This Useful Post:
    filipc (20th February, 2019)
  3. #2
    Member zozi's Avatar
    Hungary
    Here are QSX15 Wiring scheme.Ablings this action. I would need to be CM 570 without drawing.
    This is more than one engine, find and check serial number and QSX15 ECM number.
  4. The Following 8 Users Say Thank You to zozi For This Useful Post:
    bulbox (13th July, 2023), darrag (19th May, 2017), DSAuto (11th September, 2018), hanzem evr (24th January, 2015), igor75 (7th January, 2017), namnet (6th June, 2021), pppotamo (24th February, 2016)
  5. #3
    HAZIM_AZR can you get the egine serial number and post it or private message me serial number , cpl number and i can look it up on quickserve for you thank you have a good day my friend
  6. #4
    thanks so much to my friends ,I'll post the engine serial number to get exact information .
    by the way i need to know how this engine work , i mean fuel system ,fuel priming ,actuators , injection system and firing , may be service manual or workshop manual give some info.
    as you know this engin not same the Heui , Meui , and standard engines work.
    and the major problem is with ecm, i have three similar engines with a different ecms.
    note: this is generator not truck .
    I am very grateful to you.
    here is the information :
    P/N 3408501
    S/N 30127714
    D/C 12062005
    E/C N11773.00
    ESN 79148364
    GOV
    THANKS IN ADVANCE
  8. #6
    Hungary
    Hi Hazim,
    Spanish language is here but 1. atacshed rar
    DIESELMAN77 more able to help you have access to Cummins Online server.
    I only 2OO6 Intercept V2 is without wiring scheme is not available online so that
    Navigation ?Digital Kaos> The Garage> General Automotive Help and Discussions? Nexiq Link USB interface cable pinout for MODBUScomunikation QSX [page3]
    good luck ZOZI
  9. The Following 3 Users Say Thank You to zozi For This Useful Post:
    autovillkriss (7th January, 2020), bulbox (13th July, 2023)
  10. #7
    many many thanks ZOZI ,
    Please could you have english service manul like this attached qsx15 rar .
  11. #8
    Sep 2010
    Dear All,
    Now, I want to connected to board, which display V,I,Hz...
    I know the board support Modbus.
    anyone help me?
    Address ??? Modbus.
    I want to connect to PLC & Board Cummins Genset
    Thanks and best regards
  12. #9
    Hungary
    Hazim, Wiving to QSX15, QST30, QSK23, QSK45, QSK60, OSK78 ECM Connectors different wired
  13. The Following 3 Users Say Thank You to zozi For This Useful Post:
    autovillkriss (7th January, 2020), bulbox (13th July, 2023), pppotamo (24th February, 2016)
  14. #10
    DK Veteran jctech's Avatar
    just beyond the edge of reason
    Default InPower for Cummins Gensets
    Hi Singleperson, to connect to the Generator controls of a QSX 15 Genset you need Inpower.
    Insite can communicate with the engine ECM, if it is a CM570 or CM850,
    Inpower is used to communicate with the PCC controller and the engine ECM if it is a Dominion controller.
  15. The Following User Says Thank You to jctech For This Useful Post:
  16. #11
    Quote Originally Posted by jctech View Post
    Please m8 could you share inpower , that will be great jop.
    I search it but never find it in DK.
  17. #12
    Quote Originally Posted by hazim_avr View Post
    I do not have InPower7 or 8
    I have InPower 6 but it expired 2008
  18. #13
    Dec 2010
    Help cummins isx wiring schematic
  19. #14
    Dec 2010
    Help me please, really need a service manual engine Cummins QSX15 Industrial (Off-Highvay) in English. Thank you very much
  20. #15
    DK Veteran zds's Avatar
    Russia
    Quote Originally Posted by Mikhail View Post
    post your ESN
