Page 2 of 16 FirstFirst 123456712 ... LastLast
Results 16 to 30 of 236
  1. #16
    DK Veteran manocao's Avatar
    it funny but i have updated inpa to 5.0.2 and it has different behaviour when connecting interface to pc:
    now it always shows both dots white, until i power pin 1 of obd2 connector in interface, moment in which it turns both dots into black
    with inpa 4.4.7, battery dot was always black (with interface plugged in pc, of course) and ignition dot turned into black only when powering pin 1 of obd2 connector in interface
    when updating, i have selected "com1" and "usb to serial adapter", maybe it got something to do with all this???????
    i see new installation has copied ftdi drivers (very old, v1.00.2115) to C:\EDIABAS\Hardware\OBD
    maybe it is the only function of selecting "usb to serial adapter"
  2. #17
    Austria
    manocao, don't need any switch for 20pin.
    cut from above obd connector where pin1 is and solder wire and to 20pin obd. Melt little plastic over it where you solder wire and cover it. Works here.
    As for usb inf, you need to restart soft to get both dots, or enter in some model and return.
    Both bl/rl can be made to detect real bat and ing as normal inf does, use same diagram for other pins.
  3. #18
    Quote Originally Posted by oep View Post
    it doesnt work for me
    both dots always white, even with interface pin16 powered, they only come black when powering pin1 (ignition)
    edit: i found out the problem:
    when upgrading i chose "usb-serial adapter" which modified a line in obd.ini (it wrote USB instead of OBD):
    Hardware=OBD
    i have edited obd.ini like above and now i got always battery dot black, and ignition dot gets black only when powering pin1
    this is normal behaviour like before
    if i edit Hardware=ADS then both dots are always black (this is for other kind of interface)
    i have realized that upgrading hasnt erased previous 4.4.7 instalation because it installs inpa 5.0.2 in different directory:
    inpa 4.4.7 ---> C:\INPA\BIN\INPALOAD.EXE
    inpa 5.0.2 ---> C:\EC-APPS\INPA\BIN\INPALOAD.EXE
    so i can use both versions
    although if i try some cars in both versions, i got errors, i think there are some .ifo files missing
    here is my obd.ini (it is located at C:\EDIABAS\Bin):
    [OBD]
    Port=Com1
    Hardware=OBD
    RETRY=ON
    ;Tracelevel=0xFFFFFFFF
    ;Tracelevel=0xF0000000
    ;Tracelevel=0x0000FFFF
    ; Bit 0 = Funktionsaufruf
    ; Bit 1 = io Ergebnis
    ; Bit 2 = nio Ergebnis
    ; Bit 3 = Detailinfos
    ; Nibble 0 = readchar_wait
    ; Nibble 1 = main
    ; Nibble 2 = cmd
    ; Nibble 3 = obd
    ; Nibble 4 = send_and_receive_...
    ; Nibble 5 = read_telegram_...
    ; Nibble 6 = send_telegram
    ; Nibble 7 = SendData
    [UNIT_A]
    Port=Com2
    Hardware=OBD
    [UNIT_B]
    Port=Com3
    Hardware=OBD
    [UNIT_C]
    Port=Com4
    Hardware=OBD
    [UNIT_D]
    Port=Com5
    Hardware=OBD
    [UNIT_E]
    Port=Com6
    Hardware=OBD
    [UNIT_F]
    Port=Com7
    Hardware=OBD
    [UNIT_G]
    Port=Com8
    Hardware=OBD
    [UNIT_H]
    Port=Com9
    Hardware=OBD
    [UNIT_I]
    Port=Com10
    Hardware=OBD
    [UNIT_J]
    Port=Com11
    Hardware=OBD
    [UNIT_K]
    Port=Com12
    Hardware=OBD
    [UNIT_L]
    Port=Com13
    Hardware=OBD
    [UNIT_M]
    Port=Com14
    Hardware=OBD
    [UNIT_N]
    Port=Com15
    Hardware=OBD
    [UNIT_O]
    Port=Com16
    Hardware=OBD
    Example for OBD.ini :
    [OBD]
    Port = Com1
    ;Einstellen der seriellen Schnittstelle
    ;erlaubte Werte: COM1, .., COM99
    TRACELEVEL = 0
    ;nur f?r interne Fehlersuche
    ;erlaubte Werte: 0=aus, ansonsten 0x00000000 .. 0xFFFFFFFF
    RETRY = OFF
    ;Wiederholung im Fehlerfall, wird von EDIABAS bereits gemacht, sollte deshalb aus sein.
    ;erlaubte Werte: OFF, ON
    MODE=NORMAL
    ;Bei KBUS werden DS2-Telegramme in K-Bus-Telegramme umgewandelt.
    ;Kommunikation nur am einzelnen DS2-Steuerger?t am K-Bus zul?ssig.
    ;erlaubte Werte: NORMAL, KBUS
    HARDWARE=OBD
    ;OBD-Stecker OBD
    ;OBD-Stecker am USB->Seriell-Adapter USB
    ;alte ADS-Hardware ADS
    UBATT=ON
    ;Bei UBATT=OFF wird der Batteriestatus nicht ?ber die Hardware ermittelt
    ;sondern fest auf „Batteriespannung vorhanden“ gesetzt.
    ;Workaround f?r den Hardwarefehler des LAPTOP DELL LATITUDE D600.
    ;Dieser ist nicht in der Lage den Batteriestatus richtig zu erkennen.
    retry: Repetition in the event of an error made by EDIABAS already, should therefore be made.
    mode: In KBUS DS2 frames in K-bus messages are converted. Communication only at the individual DS2-control device on the K-Bus permitted.
    ubatt: In UBATT = OFF, the battery status is not determined by the hardware but firmly "available battery voltage" on set.
    Workaround for the hardware failure of the LAPTOP DELL LATITUDE D600.
    This is not really in a position to recognize the battery status.
    SAY THANKS!!
  4. #19
    Pitesti,Romania
    my real ignition mod .
    for those who are wondering why is not working with 20pin adapters: those adapters don't have the ignition pin/wire
  5. #20
    i see this is source web of kkl mod
    My DIS/INPA/SSS/CARSOFT/NAVCODER Interface. - Bimmerforums - The Ultimate BMW Forum
    great bmw forum there
  6. #21
    Member yorugualoco's Avatar
    Quote Originally Posted by manocao View Post
    I post in several forums under my nick name "LOCUM" but it was unavailable here on DK
    anyway you can take a look here (spanish language)
    http://www.bmwfaq.com/f16/interface-...or-20-a-524852
  7. #22
    i m8
    got 1 more question:
    i installed several inpa versions, some set interface as OBD and others as ADS by default, what's the difference? OBD=16pin and ADS=20pin connectors? how must i config .ini files with your modded interface? OBD or ADS?
    edit: sorry, i found the answer or your other forum: Interface =STD:OBD
    Configuraciones para el DIS
    EDIABAS (en windows)
    Configuraci?n del c:\ediabas\bin\ediabas.ini, ojo no es el archivo completo, en negrita son los par?metros
    que hay que poner dentro del archivo
    ;EDIABAS 6.4.7 Configuration
    [Configuration]
    Interface =STD:OBD
    LoadWin32 = 1
    ;TCP/IP Configuration
    [TCP]
    ; RemoteHost
    ; Description : server address/name
    ; Default = diaghead
    RemoteHost = 192.168.68.1
    ; Port
    ; Description : IP communication port
    ; Value : 1000 < port < 30000
    ; Default =
    Port = 6801
    c:\ediabas\hardware\obdsetup.exe, que este todo ok
    ps: i saw this info on ebay
    this is serial rs232 interface
    source: http://cgi.ebay.com/ebaymotors/BMW-I...motiveQ5fTools
  8. #23
    so, what was your question?
  9. #24
    Austria
    maybe he's gets horny on bimers as chicks do..
  10. #25
    DK Veteran lee_hdi's Avatar
    Sheffield
    Is this to work with DIS software? or another piece of software?
    Sorry if that seems a stupid question, I'm just starting with diagnostic software, so just doing a bit of research
  11. #26
    Default interface
    hi
    interface with the chip pins 17-18-20 ft232bm are bound together but when installing the BC546 transistor pin 20 is no longer linked to the 17 and 18 do not understand can you explain?
  12. #27
    Quote Originally Posted by zeca View Post
    hi
    well, the reason to make Ignition circuit, it's to be able to do CAR KEY MEMORY and some others features in DIS or SSS.
    If you don't do ignition circuit you still can diagnosis and clean error memory.
    In ftdi232 BM/BL pins 17 and 18 are #ri and #gnd, if you solder them you will have allways battery ON, meanwhile pin 20 is #dsr and goes to ignition
  13. #28
    Quote Originally Posted by lee_hdi View Post
    mate have you READ the title of this thread?
  14. #29
    Quote Originally Posted by djcristi View Post
    Mate why you say it doesn't work with 20 pins cars?
    It work's on my 20 pin diag 530d E39, i think you are talking about ADS cars and NOT 20 Pins diag port
  15. #30
    Austria
    Quote Originally Posted by yorugualoco View Post
    Boys, chino obd2 to round connector is not fully populated (not all wires are connected, pin20) that's why is not working.
    I already wrote this shit before, so you could read and make yours working correctly.
