I don't have the SGBD folder, Sombedy could give a copy?
Thanks a lot
error ifh003 from ediabas doku:
IFH-0003: DATATRANSMISSION TO
INTERFACE DISTURBED
EDIABAS_IFH_0003
Meaning: A response from the interface was incorrectly received
(characters were lost, protocol frame incorrect, etc.).
Causes: Contact problems in the cables between the host
system and EDIC-GH.
Error correction: Check the cables between the host system and EDIC-
GH.
Target system: WIN SCO QNX
Thanks a lot
check here
not that hard, isn't it
I have the same problem with obdsetup.exe is also missing on my package :-(
why not buy real inpa for 20 quid from ebay
hi chaps
Can someone with good experiance with these cables
please have a look at this one,
And tell me if this is correct,
Chip is FTDI FT232BL
pins 20 & 21 are connected
And pins 22 & 23 also connected
THIS UNIT HAS NOT BEEN MODED YET..
i have moded another unit, which i cant get to work
..suspecting software setup but really need this hardware checked first...
the one i moded also has these pis bridged but look more like error that correct,
Anyone come across these before??
THANKS GUYS
EDIT: I guess these cables require this bridge as all is ok now,
Still in the workshop.
if this post was use full
please press
the thanks button
I have the same interface as yours (and probably another thousands peoples ) but those pins are not shorted. Looks like you have to desolder those first and then start making changes .
Very, very, very good post, a lot of work man. Thanks
Thanks M8
been struggling to connect to vehicle at pressent,
thought i had hardware issue, but after clearing tools away
and popping back to car for a quick look, i noticed that the
16 pin OBD connecter is not fully populated, E39 1999.
i have an under bonnet adaptor arriving soon so will update once i have had a chance to test...
please press
the thanks button
Quick update,
finally have full connection with car..
1, had issue with software, so a MASSIVE THANKS to FAL for his help with this....
2, was trying to read vehicle through OBD but this vehicle
99 E39, but needs to be accessed through 20 pin under the bonnet. Massive thanks to this thread for the answeres that i needed....
this is why my OBD had no connection to Inpa...
please press
the thanks button
i left the bridges in place, because i did try to remove them for testing but found "pcb tracks" under them so put those bridges back in..
No other changes to cable, just followed exactly what was in this thread,
the faults i had was
a, using wrong version of inpa,
Fal sorted that for me, now using 90X version of inpa..
b, i was trying to conect to car via OBD until i looked at connector and only saw 4 pins in the obd socket,
i can confirm bridges are ok, and connected to car with
1, 409 cable with Ignition Sence & 20 pin adaptor..
2, 409 cable without Ignition Mod & 20 pin adaptor..
Both work fine,
409 cable with ignition sense never throw "ignition on" dot on screen but still connected with car..
I need to make New 16 Pin OBD to 20 pin BMW adaptor
which has pin 1 of OBD connected to the 20 pin, so i can have Real igntion sense,
but not really nessasary, i would just like it...
I would just like to say again, that this is a FANTASTIC thread
and a big thanks to everybody for the great info
please press
the thanks button
