Golf Plus .... ECU Problem ?
Results 1 to 4 of 4
    Top Poster + DogdySnigwirter's Avatar
    Default Golf Plus .... ECU Problem ?
    VW Golf Plus has Traction Control light on at all times.
    A 5051 check was carried out by VW.
    Result, as printed on Invoice :
    1 FAULT IN BRAKE ELECTRONICS
    0143 BRAKE PRESSURE SENSOR 1 G201 ELECTRICAL
    MALFUNCTION IN CIRCUIT STATIC
    NEW ABS UNIT WITH ECU REQUIRED
    There has been no change to the cars performance whatsoever.
    Is there a way to switch light off on dash or is it a case of a new ECU ?
    DS
    Quote Originally Posted by DogdySnigwirter View Post
    DS
    you can change only BRAKE PRESSURE SENSOR with one from scrap , but first time check wires from sensor ...
    DK Veteran avtonega's Avatar
    EU
    Locatoin of brake pressure is inside of ABS Hydraulic block!
    You can change it with used one, ABS-ECU must stay the same!
    Thanks guys
    Any Idea where to get this done/fixed and how much should I be looking to pay ?
