Audi A4 2.0 tdi DPF cannot remove 0281013293
Results 1 to 7 of 7
    world wide
    Default Audi A4 2.0 tdi DPF cannot remove 0281013293
    I need DPF remove for Audi A4 2.0 tdi (140 hp) 2008 ECU Bosch 0281013293, 03G906016KN.
    I was trying with ECU Safe 1.9.1.6b (cracked version) but the DPF light cannot be removed from dashboard and no power from the car (low power from engine).
    All operations made with Byteshooter.
    Looking forward for your dumps.
    world wide
    Default original dump
    original dump here
    Aug 2009
    Bulgaria
    post result pls !
    pass on Pm
    br
    Jun 2010
    its better when you go to a tuner wich has knowledge about it. Its very difficult to do it because its the biggest part of the structure in the ecu.the ecu has many protection functions for the dpf and when you make it wrong the car goes into limpmode.It is more work as you believe.
    Quote Originally Posted by augustinbz View Post
    Sep 2009
    Lithuania
    original dump here
    Test this and post results
    P.S. you must remove DPF physically first.
    DK Veteran rsibiza's Avatar
    Wink
    If you dont remove DPF first,the DPF will be blocked by particles,that are no more burned as you removed that function by DPF off....but the filter still there.
    result can be lost of power...ECU MIL on....burning DPF filter,maybee car.
    Unmount first your DPF,clear error DTC s in ecu,do the ecu DPF off...now your car will run fine
    Mar 2011
    Talking thankyou
    Thanks for the information,i presume the procedure is the same for sn audi a6 2.0tdi 140 2008.
