Results 1 to 13 of 13
    Aug 2009
    Default Washing machine stopped working
    my washing machine stopped working this afternoon , the dial got stuck on 10 minutes and wouldnt move or drain off and it was making this buzzing noise has does any1 know what the problem might be please help thankyou sorry forgot to say my washing machine is a whirlpool 5726 1400 .
    racin-snake's Avatar
    Jun 2009
    might be a coin or a bra wire in the pump rotor
    common to stop the pump rotating and if the water dont drain it will stop program
    Today is the Tomorrow you worried about yesterday ......Was it worth it ?
    V.I.P. Member patkins's Avatar
    Cuckooland Banana Republic
    Could be your filter is blocked from fluff.
    Filter is usually located towards bottom of front of machine behind a round or square door.
    Problem is that the machine is full of water so you should try to find someway of catching the water or chanelling it away from your machine before you open the filter aperatus located behind said door.
    Whirlpool are or can be a troublesome make.
    Aug 2009
    i have managed to drain the water out i had to open the door , i will have a look at the might be a coin or a bra wire in the pump rotor
    common to stop the pump rotating and if the water dont drain it will stop program and Could be your filter is blocked from fluff.
    Quote Originally Posted by femmym View Post
    Is it just me or is there an echo in here?
  6. The Following User Says Thank You to patkins For This Useful Post:
    Meat-Head (3rd December, 2017)
  7. #6
    DK Veteran manxspud's Avatar
    Jul 2009
    Its not just me then
    @manx
  8. #7
    Bulld0g's Avatar
    Apr 2008
    Liverpool
    seems like
  9. #8
    DK Veteran ste6106's Avatar
    Mar 2009
    Bolton
    When mine breaks down I give her a slap......
    Life is a party and parties arent meant to last.
  10. #9
    Sep 2010
    io non parlo inglese, ma cosa c'entra la lavatrice qui?
  11. #10
    DK Veteran Grizz's Avatar
    Sep 2010
    Ireland
    Quote Originally Posted by miomao View Post
    io non parlo italiano, ma la lavatrice ? rotta.
    benvenuti a DK
  12. #11
    DK Veteran jcgrumbles's Avatar
    Nov 2010
    north east england from the posh end of scotswood road
    Christ,ive went dyslexic
  13. #12
    Jan 2011
    Check pump. Is something is stuck in it, the washing program stops.
  14. #13
    Nov 2011
    rominia
    Hello!
    I have a problem with my Whirlpool awt 7125/1 washing machine. For a few days he no longer wants to enter the centrifuge, wash his platoon, turn the cuvette to the left and right, evacuate the water, and when he gets to the squeeze he does not do anything, just wait until he stops. Annoying is that it does not give any error code. Can someone help me? Thank you.
