Results 1 to 1 of 1
    Sep 2010
    Default How to flash DM500 using telnet
    To flash an image using Telnet
    This method will only work with a .img image file.
    * Rename the image file to backup.img
    * FTP the image file to the /tmp folder on the dreambox
    * Telnet to your box and paste the following command:
    cd /tmp && eraseall /dev/mtd/3 && cp backup.img /dev/mtd/3 && reboot
    To telnet, click START > RUN and type Telnet ip.address.of.dreambox A command window will appear, enter username root and password dreambox.
    To backup an image using Telnet
    * Telnet to the box and paste the following command:
    cat /dev/mtd/3 > /tmp/backup.img
    * FTP to the box and navigate to the /tmp
    * Here you will find the backup.img file.
    How to copy an image from your PC to the Dreambox via Telnet
    First of all, you need to have a mounted directory from your PC. Make sure you have the image.img file in your mounted directory on your PC. Telnet to the dreambox and paste this command:
    cp /hdd/movie/image.img /tmp/image.img
    The img will be copied from your mounted directory to the /tmp folder on the dreambox ready to be flashed.
  2. The Following User Says Thank You to arrow For This Useful Post:
    smallclone (22nd November, 2013)
