Page 3 of 149 FirstFirst 123456781353103 ... LastLast
Results 31 to 45 of 2225
  1. #31
    Aug 2010
    i am a newbie to this , i have a dm800, how do i use this file and where should it go...please help
  2. #32
    V.I.P. Member SGTFlipFlop's Avatar
    Scotland
    Quote Originally Posted by browno View Post
    http://www.digital-kaos.co.uk/forums...75/#post810782
  3. #33
    Aug 2010
    i have tried this and it says error: no associated services...help please!
  4. #34
    Aug 2010
    got it working , thank for your help
  5. #35
    Scotland
    Hurray, Good news.
    See follow guides and it all fits into place
  6. #36
    Aug 2010
    what is a picon and what do i do with it?
  7. #37
    Scotland
    Gives you the channel icons on the info bar
  8. #38
    DK Veteran wooper's Avatar
    Sep 2008
    Great work and thanks.
    Will this overwrite my old Bouquets or do I need to delete them?
  9. #39
    Scotland
    It will overwrite them mate
  10. #40
    Default Picons
    Can anyone explain how to install Picons on a dm500hd running dream elite?
  11. #41
    Aug 2008
    Picon for BBC One HD ? its using the BBC HD one also picon for MAX is wrong
    Thanks !
  12. #42
    Scotland
    Quote Originally Posted by lombard View Post
    Thanks !
    There was no BBC One HD at the time, When I filled in the set
  13. #43
    DK Veteran melloned's Avatar
    Nov 2008
    cheshire
    Hi , does this channel list have the football first channels on ?
    Thanks.
  14. #44
    Scotland
    Quote Originally Posted by melloned View Post
    Thanks.
    Yea, They do, They keep changing the screen numbers, But all games are about to start showing in 1 min
  15. #45
    Scotland
    Here is the latest update
    DreamboxEdit 4.0.0.0 Used (Recommended) Guide Here
    Updates: 31st October 2010
    DM800 Bouquet Only
    ITV3 HD (New Channel)
    ITV4 HD (New Channel)
    Sky Box Office (4 Channels, Frequency Changes)
    Removed Channels
    None
    Picons
    Updating nearly 50 picons too better ones and nearly fully updated Channels (Except Adult)
    ** Edit your own BBC & ITV Regional channels to suit your needs in DreamboxEdit (If you are from Ireland, I've renamed all Irish channels so easy for you to find) **
    Also added Picons for Sky UK (Base set from Picon4U) and the rest updated by myself
    Use any FTP client, DCC for example, to transfer the picon directory
    to one of the following paths on Flash, HDD, CF or USB respectively:
    /usr/share/enigma2
    NOT recommended, because of limited capacity of the flash memory
    /media/hdd
    HDD will keep running indefinitely and may affect image performance
    /media/cf
    Recommended if CF available and successfully mounted (8000/800)
    /media/usb
    Recommended if USB available and successfully mounted (8000/800)
    Picon will display immediately on zapping, no further setup required!
    Always remove old picons from Dreambox before uploading new ones, Sometimes they don't overwrite correctly
    Please keep this thread clean, Use the Thanks button rather than posting on the thread
