Page 144 of 149 FirstFirst ... 4494134139140141142143144145146147148149 LastLast
Results 2,146 to 2,160 of 2225
  1. #2146
    V.I.P. Member SGTFlipFlop's Avatar
    Scotland
    Fully updated, found a few channels that aren't updating so had to do them manually, All working now, Enjoy
  2. The Following 5 Users Say Thank You to SGTFlipFlop For This Useful Post:
    DanSilov (20th October, 2013), deadman23 (18th January, 2014), johnviv (30th November, 2013), stigmata1823 (20th October, 2013), yosibest (17th December, 2013)
  3. #2147
    Nov 2012
    Cheers for the update, Setanta and BT Sports still not working for me on that new version, strange!!
  4. #2148
    Scotland
    Definitely working as I'm watching UFC now on BT Sports 1
  5. #2149
    P&D's Avatar
    Quote Originally Posted by aidang View Post
    both working for me
  6. #2150
    Mar 2011
    Might be silly question, but how do I split the bouquet for just Enigma1? Thanks
  7. #2151
    DK Veteran piopat's Avatar
    May 2008
    im not sure what you mean split but you can change an enigma 2 bouquet to enigma USING DREAMBOX IT , click on tools and there are options and one option is toggle between , click on that and it will change your bouquet from 2 to 4 and 4 to 2 , that's between e1 and e2 .otherwise you need an e1 bouquet which I don't think sgt is doing any more or you can use dreambox edit to create your own bouquets , its not that hard to make a basic bouquet (I mean with no sky numbers etc) so that's some thing you may consider .
    i love it when a dreambox comes together.
  8. #2152
    hi need help to locate latest file boquets e1 thanks cant find thanks
  9. The Following User Says Thank You to nas4u For This Useful Post:
    jims (3rd November, 2013)
  10. #2153
    Scotland
    New update will be out tomorrow, Loads of changes from last update, Lots of work
  11. The Following 2 Users Say Thank You to SGTFlipFlop For This Useful Post:
    Klip (22nd November, 2013), Rodbouy (22nd November, 2013)
  12. #2154
    Scotland
    Here is the latest update
    DreamboxEdit 5.3.0.0 Used (Recommended) Guide Here
    Enigma 1 = Dreambox 500, 600, 7020 | TechnoMate 500, 500 Super, 600 | Blade Media 500
    Enigma 2 = Dreambox 800(SE), 8000, 500HD, 7020HD | VU Uno, Solo, Duo, Ultimo | ET 5000, 6000, 9000, 9100, 9200 | TechnoMate 500HD, 800 and many more....
    Updates: 22nd November 2013
    Bouquet Updates
    Massive update, again too many too list, fully updated channel list and Picons
    Before these Numbering bouquets work you need to make some changes to DBE and your Enigma2 box
    For Regional changes you will now need to do these in SGTFlipFlop & Entertainment bouquets now.
    in DBE options > advanced > make sure all boxes are ticked especially Allow Duplicate Entries
    On Dreambox make sure Multi Bouquets are ticked (Menu>Setup>System>Customize>Expert>Enable Multi Bouquets-YES)
    The text in bold needs to be done before you open the bouquets in DBE, Thanks
    Updates
    Too many to mention just enjoy, Any errors let me know
    Removed Channels
    Too many to mention
    Picons
    Updated newest channels
    ** Dumped Multi Bouquet, Don't Use My Dish No More Pointless Updating, Check Out Catseye settings, Excellent **
    These bouquets are positioned nearly identical to the Sky Box, Enjoy a neat up to date bouquet.
    ** Edit your own BBC & ITV Regional channels to suit your needs in DreamboxEdit (If you are from Ireland, I've renamed all Irish channels so easy for you to find) **
    Also added Picons for Sky UK,
    All correctly mapped and a few obscure ones missing only
    Use any FTP client, DCC for example, to transfer the picon directory to
    one of the following paths on Flash, HDD, CF or USB respectively:
    /usr/share/enigma2
    NOT recommended, because of limited capacity of the flash memory
    /media/hdd
    HDD will keep running indefinitely and may affect image performance
    /media/cf
    Recommended if CF available and successfully mounted (8000/800)
    /media/usb
    Recommended if USB available and successfully mounted (8000/800)
    Picon will display immediately on zapping, no further setup required!
    Always remove old picons from Dreambox before uploading new ones,
    Sometimes they don't overwrite correctly
    Please keep this thread clean, Use the Thanks button rather than posting on the thread
  13. The Following 14 Users Say Thank You to SGTFlipFlop For This Useful Post:
    atlas1888 (8th January, 2014), bigup (23rd November, 2013), damiensk (15th January, 2014), hendy21 (22nd November, 2013), irsh12 (24th November, 2013), jimbob1211 (25th December, 2013), Klip (22nd November, 2013), mcmlxviii (24th November, 2013), Mr S (23rd November, 2013), raz0r19 (26th November, 2013), Red Scouser (22nd November, 2013), Rodbouy (23rd November, 2013), strummer (22nd November, 2013), xario (23rd November, 2013)
  14. #2155
    Hi where is the enigma1 files? cant seem to locate them only enigma2 showing in your attachments.
  15. #2156
    Scotland
    Got rid of Enigma1 files ages ago
    Sent from my HTC One using Tapatalk 2
  16. #2157
    Scotland
    Updates: 27th November 2013
    Channel 5 HD (New Frequency)
    More4 HD (New Frequency)
    MTV Classic Renamed to MTV Xmas
    Removed Channels
    Channel 5 HD
    More4 HD
    Picons
    /usr/share/enigma2
    /media/hdd
    /media/cf
    /media/usb
  17. The Following 13 Users Say Thank You to SGTFlipFlop For This Useful Post:
    chavscum (9th December, 2013), ChrisMac1105 (29th November, 2013), DeejayAJ (1st December, 2013), Fretman (1st December, 2013), jabz123 (11th January, 2014), johnviv (30th November, 2013), lovetv (3rd February, 2014), mcmlxviii (29th November, 2013), mikk (28th November, 2013), milsim (1st December, 2013), roseraja (6th December, 2013), stigmata1823 (3rd December, 2013)
  18. #2158
    Scotland
    BBC Four HD (New Channel)
    BBC News HD (New Channel)
    BBC Three HD (New Channel)
    CBBC HD (New Channel)
    The Style Network Renamed to E! +1
    Nick Jr. Renamed to Nick Jr Xmas
    Nick Jr. Peppa Renamed to Nick Jr. 2
    S4C (New Frequency)
    Showcase 2 +1 (New Frequency)
    Sky Movies Drama & Romance Renamed to Sky Christmas
    Sky Movies Drama & Romance HD Renamed to Sky Christmas HD
    Removed Channels
    The Style Network
    Picons
    /usr/share/enigma2
    /media/hdd
    /media/cf
    /media/usb
  19. The Following 14 Users Say Thank You to SGTFlipFlop For This Useful Post:
    a7v8x (23rd December, 2013), androp (14th December, 2013), deegee7456 (15th December, 2013), Digicom (3rd January, 2014), ikki234 (13th September, 2014), johnviv (1st January, 2014), Legi0n (15th December, 2013), maj08 (26th December, 2013), P&D (11th December, 2013), reddiamond (3rd January, 2014), stigmata1823 (11th December, 2013), stonewall (12th December, 2013), weedman (29th December, 2013), wmccull (4th January, 2014)
  20. #2159
    is star HD working for everyone ??
  21. #2160
    Quote Originally Posted by hkambo View Post
    worked out my own answer ...changed the modulation to 8PSK and all working now inc WATCH HD which was also affected
