Here is the latest update
DreamboxEdit 4.1.0.1 Used (Recommended) Guide Here
Enigma 1 = Dreambox 500, 600, 7025
Enigma 2 = Dreambox 800, 8000, 500 HD
Updates: 8th August 2011
Bouquet Updates
Motors TV (New Frequency)
MUTV (New Frequency)
Added a few other Foreign Satellites
Removed Channels
Picons
Added for the 2 channel changes above
I will be doing Enigma2 Multi Bouquet, But will not for Enigma1 as it takes too long to remove every HD channel from all satellites, Easily too do yourself if you have the time.
** Edit your own BBC & ITV Regional channels to suit your needs in DreamboxEdit (If you are from Ireland, I've renamed all Irish channels so easy for you to find) **
Also added Picons for Sky UK,
All correctly mapped and a few obscure ones missing only
Use any FTP client, DCC for example, to transfer the picon directory to
one of the following paths on Flash, HDD, CF or USB respectively:
/usr/share/enigma2
NOT recommended, because of limited capacity of the flash memory
/media/hdd
HDD will keep running indefinitely and may affect image performance
/media/cf
Recommended if CF available and successfully mounted (8000/800)
/media/usb
Recommended if USB available and successfully mounted (8000/800)
Picon will display immediately on zapping, no further setup required!
Always remove old picons from Dreambox before uploading new ones,
Sometimes they don't overwrite correctly
Please keep this thread clean, Use the Thanks button rather than posting on the thread
