I have just tried to load SGTFlipFlop ENiGMA2 12.08.11. into dreamedit but I get a message saying "no service File Found"
Am I doing something wrong? Any help would be most appreciated
Under options in Dreamboxedit make sure the settings are set to Enigma2
I have checked and dreamboxEdit is set to Enigma2 The message also says "you must first use FTP option to copy all the necessary files from the dreambox to your PC"
open the prog up, under options make sure everything is filled in correctly then press save. Go to open and point it to the directory your bouquets are stored in.
When everything loads up click on ftp and send files to Dreambox
What version of DBE are you using ? I'm using 3.0.0.0 which is available in the downloads section, there are other versions there too.
Hmmm try redownloading the bouquets again m8
I have a mac anyway to get my channel list upgraded my mutv is now a cartoon channel as i heard it has changed frequency. Im new to this my box is a dreambox 800hd clone.
update to the newest IHAD version of DBE as thats what was used to create the bouquets. DBE 3.0.0.0 is vastly outdated.
to be honest it would take you many hours of editing to do this. if you want a bouquet that is tailored to sky uk with the corresponding channel numbers either search for silverfox0786 / VIX settings or download and use the B16MCC dreamboxuk services database software to create your own.
i;m not detracting from the pack that SGTFlipFlop makes but it would be a lot of work to edit his pack when there are already packs available.
try double clicking on the file twice, on my download its a file within a file called the same
someone help me .. i've tried numerous different folders and way to put the picon folder on.. i have got newnigma2 image.. ive tried it on the usb and internal flash and even the ones downloaded directly from the installer on the image not working
