Here is the latest update
DreamboxEdit 5.0.1.0 Used (Recommended) Guide Here
Enigma 1 = Dreambox 500, 600, 7020 | TechnoMate 500, 500 Super, 600 | Blade Media 500
Enigma 2 = Dreambox 800(SE), 8000, 500HD, 7020HD | VU Uno, Solo, Duo, Ultimo | ET 5000, 6000, 9000, 9100, 9200 | TechnoMate 500HD, 800
Updates: 28th March 2012
Bouquet Updates
Body In Balance Renamed To LiveXXXBabes
CBS Reality (New Frequency)
Channel 4 HD (Fixed)
ITV Meridian SE (Updated Frequency)
ITV Tyne Tees (Updated Frequency)
Sky Atlantic Ireland (New Frequency)
Sky Sports 1 For Pubs (New Frequency)
Sky Sports 3 For Pubs (New Frequency)
Sky Sports 4 For Pubs (New Frequency)
Sky Sports Interactive (Fixed Few Channels)
Removed Channels
CBS Reality
Current TV
ITV Meridian E
ITV Meridian SE
ITV Tyne Tees S
Picons
Updated newest channels
These bouquets are positioned identical to the Sky Box, All that is different is the numbering which I find to be very messy when done so I leave it how it is. Enjoy a neat up to date bouquet.
I will be doing Enigma2 Multi Bouquet, But will not for Enigma1 as it takes too long to remove every HD channel from all satellites, Easily too do yourself if you have the time.
** Edit your own BBC & ITV Regional channels to suit your needs in DreamboxEdit (If you are from Ireland, I've renamed all Irish channels so easy for you to find) **
Also added Picons for Sky UK,
All correctly mapped and a few obscure ones missing only
Use any FTP client, DCC for example, to transfer the picon directory to
one of the following paths on Flash, HDD, CF or USB respectively:
/usr/share/enigma2
NOT recommended, because of limited capacity of the flash memory
/media/hdd
HDD will keep running indefinitely and may affect image performance
/media/cf
Recommended if CF available and successfully mounted (8000/800)
/media/usb
Recommended if USB available and successfully mounted (8000/800)
Picon will display immediately on zapping, no further setup required!
Always remove old picons from Dreambox before uploading new ones,
Sometimes they don't overwrite correctly
Please keep this thread clean, Use the Thanks button rather than posting on the thread
