Page 1 of 149 1234561151101 ... LastLast
Results 1 to 15 of 2225
    V.I.P. Member SGTFlipFlop's Avatar
    Scotland
    Default SGTFlipFlop SKYUK Bouquets - Updated Regularly
    Latest Bouquets always at the end of the thread or click this link
    11th December 2013 (Latest Bouquets)
    http://www.digital-kaos.co.uk/forums...ml#post2171809
  2. The Following 6 Users Say Thank You to SGTFlipFlop For This Useful Post:
    bobo06 (23rd October, 2013), gigaz (7th March, 2014), ognib999 (7th October, 2013), petemac (22nd October, 2013), Pwack (22nd April, 2013)
  3. #2
    Top Poster + damiensk's Avatar
    manchester
    asking cos i dont know,
    u have 2 d/l 4 dm800 e2, apart from 1 being a bigger file than the other, can u tell me what is the diffrence.
    does multi mean for more than 1 satallite?
    if i ftp the multi one sat must i always have to do a full scan on each sat after its send to box?thanks
    manchester
    ive got the answer to my own question, so sorted now.
    i dont think u have to do a full scan one each sat,
    can u actually get every sat in that list?
    i know i cant.
    Sep 2010
    Quote Originally Posted by damiensk View Post
    i know i cant.
    erm the whole point of a bouquet pack is that once loaded you dont have to scan any thing as the bouquet contains all the necessary information etc.
    if you did want to go all OCD you could load a new satellites.xml file onto the box every other week and do a rescan of any satellites you used regularly, however that would be a bit pointless as SGTFlipFlop updates his packs very often.
    Aug 2008
    ITV 2 HD comes up as DVB service and says tuner failed ? using DM800 with inline amp, ?
    THanks
    Scotland
    Quote Originally Posted by lombard View Post
    THanks
    I've fixed that for the next update, When I imported the channel it has changed the Symbolrate and FEC, Should be 29500 / 3/4
    Aug 2008
    Quote Originally Posted by SGTFlipFlop View Post
    I did a manual scan on that and it starting working
  10. #9
    Scotland
    Not sure why it changed when importing, Something I need to keep an eye on
  11. #10
    Sep 2010
    yeah the same thing has happened with a few different bouquet packs by different teams. not sure why though.
  12. #11
    Scotland
    There should be an update out, Later tonight or tomorrow morning
  13. #12
    hi guys,i'm a noob ,i'm struggling with putting these bouquets onto my dm 800.i'm trying to use dcc to transfer them over.I cant get the file to go over,any ideas?
  14. #13
    Sep 2010
    Quote Originally Posted by mr e View Post
    thats your problem mate, you dont use DCC you use DBE aka DreamBoxedit.
  15. #14
    Scotland
    Updates: 4th October 2010
    DreamboxEdit 3.1.0.2 Used (Recommended)
    Updates: 30th September 2010
    DM800 Bouquet
    40 n Naughty (New Channel)
    Disney XD HD (New Channel)
    Sikh TV (New Channel)
    Fixed ITV2 HD
    Removed Channels
    Faith World +1
    Picons
    Will update them tomorrow
    ** Edit your own BBC & ITV Regional channels to suit your needs in DreamboxEdit (If you are from Ireland, I've renamed all Irish channels so easy for you to find) **
    Also added Picons for Sky UK (Base set from Picon4U) and the rest updated by myself
    Use any FTP client, DCC for example, to transfer the picon directory
    to one of the following paths on Flash, HDD, CF or USB respectively:
    /usr/share/enigma2
    NOT recommended, because of limited capacity of the flash memory
    /media/hdd
    HDD will keep running indefinitely and may affect image performance
    /media/cf
    Recommended if CF available and successfully mounted (8000/800)
    /media/usb
    Recommended if USB available and successfully mounted (8000/800)
    Picon will display immediately on zapping, no further setup required!
    Please keep this thread clean, Use the Thanks button rather than posting on the thread, Details on how to via DreamboxEdit is widely available on the net.
  16. #15
    Scotland
    Picons now updated
  17. The Following User Says Thank You to SGTFlipFlop For This Useful Post:
    gaz786 (25th November, 2013)
