Ford SRS Unit - What chip is this?
Results 1 to 12 of 12
    Default Ford SRS Unit - What chip is this?
    Hi everyone. I am trying to teach myself chip programming by practicing on some bad airbag modules. There isn't a lot of information or manuals out there on chip types and actually reading the chips, so I am trying to learn by practicing.
    I have this module from a 2002 Ford F-150 Pickup, and I can't figure out what kind of chip it is. The connector looks like it could be a bosch, but it does not say bosch anywhere.
    There are three chips. I can't find any datasheets for them.
    One is Infineon
    71001FAR001
    a2c18576
    V1-3 F1
    The second has the mark of Texas Instruments and these numbers:
    760027clc009
    980 s1F35034PG
    F20-31A0L6W
    The third just has numbers:
    6975545348
    0252
    71025ae3
    From my research I have learned that you can read some ford bosch units through the k-line, but this connector has no pins where the k-line seems to be normally found (from pictures I found in other posts).
    I understand that maybe these can be reset using ford IDS/VCM, but again, I am trying to learn. Any help would be greatly appreciated. I am attaching photos of the connector and board.
    fuktak's Avatar
    Sep 2010
    Bulgaria
    Quote Originally Posted by lawdog1 View Post
    One is Infineon
    71001FAR001
    a2c18576
    V1-3 F1
    760027clc009
    980 s1F35034PG
    F20-31A0L6W
    6975545348
    0252
    71025ae3
    Type number of srs unit
    hi there, this is a bad one to pratice on as it has a TI chip inside and unles you have a programmer that will read and programme this chip you have no chance. you can reset nearly all late ford with the vcm you need to read the fault codes then highlight the fault code that says lateral acceleration threshold exceeded crash detected. do a pin point test on it and it will ask if you want to erase the crash memory click yes let it finish then go back delete the fault codesand they will all clear. have never tried it on an f-150 but works on all other late fords.hope this helps
    regards
  4. The Following User Says Thank You to modulegod For This Useful Post:
    fuzz1 (5th November, 2021)
    The model number is:
    1L3A-14B321-AD
    02/11/2003 (sorry I said 2002, but it is 2003)
    2001 PN96
    szkeptmen's Avatar
    Hungary
    Crash data stored in a Texas processor, like in some
    Honda modules...
    Exists a good tool to clean crash data...
    WBR, szkeptmen
    fuktak's Avatar
    Sep 2010
    Bulgaria
    1L3A-14B321-AD
    2001 PN96
    Chinese sells Honda Srs Resseter.Maybe it help to you.Best Regards
    Quote Originally Posted by modulegod View Post
    regards
    Thanks for your reply.
    I was afraid that might be the case. I have only ever played with 8 pin SOIC style modules in Nissans, which are very straight forward. I wanted to learn more on how to access the memory of the MCU style chips. I don't mind investing in the hardware. Is there any way to tell what type of TI chip it is so I can look for the right programmer?
    Try with the IDS
  10. #9
    Jul 2016
    USA
    very strange module / mcu this is.
    did you friends find solution to this ?
    is it worth investing in buying a tool for this mcu ? since modules with these chips are older models ?
  11. #10
    I am running into this module also in a ford ranger 2004 any finding on how to clear these?
  12. #11
    Jan 2018
    NY, USA
    still looking for solution. anyone ?
  13. #12
    dmka's Avatar
    Oct 2013
    Vatican City
    3 year old thread.... what do you need?
