I believe the Main rom file has been modded to ignore activation.
If you want people to look at it, you must give as much information as possible regarding what happens.
Are you saying that the trial counter stays at 10 and does not count down?
Yes. reworked master file. (mainprogramm)
The device accepts any updates.
impactops, I installed both main and updates. it workswithout any need to register, no countdown from 10, just as a registered unit works.
Can you post the Main program file that is modded?
k_algulam (15th August, 2018)
If buksir wants it to be worked out then let him post it here and i'll see what i can do.Sorry, only seeing this now. PM your email and I will send it to you. Not sure if buksir wants it posted here or if i am allowed.
Impactops
Thanks for the file Autofix,
They are using the Main program from Hi-Scan Lite, It is identical to the C2 but it is there OEM tool for Hyundai & Kia.They have modfiied it to appear as if it is MAIN10B0ENG and the splash screen has been changed to CS2 aswell as the file being dated 2007.The Main program for Hi-Scan lite does not require you to register the roms since it is meant for delears only.But i believe you will run it into problems down the track, it is missing some information that is required for the C2 updates.From memory there is also an option in the config menu that allows delears to enter there Dealer info, whatever you do don't enter data in that field.It writes that information in a portion of memory that configures the unit and it will overwrite values that are used in the C2.
Nextech Service Solution
Below is the HI-Scan Lite Splash Screen
I need an update for a AD 300 or Carman 1 for Jap vehicles. Can anybody help as they say the upates have stopped for this model. Many thanks. I have got HP630 if you need it
I do not know much English.
Hard for me to understand this forum.
Do not blame her. Working through Google Translator
hi friend
i need activation VERSION 10B0
please i need that calculator
thankss
I would also like the calculator.
Many thanks
hi
please help me
Useless also, it need dongle to code...I would also like the calculator.
Many thanks
