I select 27-1 then i have new window but my program doesn't select my ECU. 27-2 the same and 28 doesn't work.
Ahh I don't know then, You'll have to mail the author and ask him if it supports your ECU.
Ok thanks, I'll mail to him. Did he answer to your mail??
martinracing (6th September, 2013)
Hello folks. I have problem with installing RX25_PC. on Windows XP SP2. I did like the Readme file says: installed dotnet 3.5 SP1, updated my windows,create the needed folders, copy the files and still doesn't allow me to install it. Do you have any ideas why? I really would appreciate some help! Thanks in advance.
PS: do i have to install the first version of the program, then upgrade it or i can install the last one + drivers?
XR25PC latest download location (more then 200 users)
install 141, it is full version
This is what happens me:
I copy ftd2xx.dll to c:\windows\sytem32
I make a directory c:\website\CLIP\resources
I copy the image files in this directory (resources.rar), BUT NOT CROMPRESSED. It is neccesary to extract the files of the compressed archive on the indicated directory.
copy the font files c:\windows\fonts (I dont know what means this part)
run setup
Hope you found this interesting.
Autoanswer:
copy the font files c:\windows\fonts means you must COPY the fonts files (not in version 1.41, you must download the original version 1.15 and use the fonts directory included), copy all this fonts to c/windows/fonts and ??? voila !!!!, it works.
Merry christmas everybody.
Thanks to everybody for the reply! I guess i have some problem with my OS at home, cause i've already installed it on a computer in my office, but still doesn't want to run at home.
Merry Christmas everybody!
Can this work on a Twingo Phase I with Marelli ECU?
Twingo has a 12pin connector. I was wondering if it would be possible to use a 12pin->16pin adapter with the blue KKL device?
Hi. I have tested as you said and work:
Twingo 1998 1,2 (55 CV), blue cable KKL, adpater 12 to 16. You can comunicate whith the ECU Magenti 6.2 (fiche 23) and you can see rpms, temperatures, inyection, advise ligths, etc.
Hope you found this interesting. Any more questions you can ask me.
Best regards.
H? people , for works with Renault XR25pc scanner , only install latest version ?
It is 1.50
Thanks.
