Page 2 of 5 FirstFirst 12345 LastLast
Results 16 to 30 of 67
  1. #16
    Top Poster charlie-h's Avatar
    Up North
    WDB2110751A123456
    25/10/2010
    code 268971
    WDB2110751A654321
    25/10/2010
    code 283676
    The above codes that i generated are the same as what you have provided. So there for it seems my key-gen is good.
    So why does DAS say wrong password when i enter it in SRS (sprinter-vito)
    I enter correct vin number and system date yet DAS does not accept.
    DAS i am using is 07/2009
    Any thoughts anyone!!
  2. #17
    Up North
    Default Version
    Version i am using is 1.5
  3. #18
    DK Veteran cocutanu's Avatar
    Jun 2009
    Quote Originally Posted by charlie-h View Post
    WDB2110751A123456
    25/10/2010
    code 268971
    WDB2110751A654321
    25/10/2010
    code 283676
    Hi there.
    I'm not saying that this is the right keygen for you...all I did is tested those info's from you to compare with what my keygen can generate. So all we have is the same keygen !
    I asked you if you are sure about this one because this one is really old and probably a new version is out there but unfortunately I don't have that one to be able to generate a key for you. As you can see cocoh confirmed that this is an old version and probably you will need a newer one (maybe he can help you ).
    Good Luck
  4. #19
    Quote Originally Posted by cocoh View Post
    this its old version...
    he needs das unlock 1.2
    yes, that should be the right keygen, I usually don't ask but I didn't found it anywhere and if can you send me a PM with it I will be more than thankful.
    Thank you very much!
  5. #20
    Jun 2009
    UK
    Hey guys.
    We are trying here to correct the Vmax on Sprinters EDC15 and EDC16. Do you know links to login generators to work on it with MB DAS?
    Any useful info would be very appreciated. Thanks!
  6. #21
    workshop
    Quote Originally Posted by worldiagnostic View Post
    Hey guys.
    EDC 15c6- no problem
    EDC 16 hard shop,i think with Ecusafe,from flash possible
  7. #22
    Jun 2009
    UK
    Quote Originally Posted by mercis View Post
    No: I looked in Xentry menu(engine ECU), that Vmax is possible to correct, but seems that it will ask for SCN coding after setting new Vmax. Would like to ask somebody who knows how to set it.
    From flash side, I know it's usually possible. But Ecushit doesn't make its job. Almost never You must make it manually.
  8. #23
    workshop
    what for sprinter want you new vmax?
  9. #24
    Jun 2009
    UK
    In this case a V6 cdi Sprinter has 130km/h limiter, and optimal maximum should be around 150 km/h in these areas.
  10. #25
    Member 4ly-syk's Avatar
    Nov 2010
    can anyone help me with the unlocker for 2010 version...
    im pretty stuck at the moment
  11. #26
    Nov 2010
    or at least anyone know where i can buy the software that can give me the passwords? please
  12. #27
    Nov 2010
    got it now so if anyone needs a password hit me up
  13. #28
    Oct 2010
    fes, Morocco
    hi yes for DK member pleaze tell us wher we can download password keygen or if you can uploadit in forum that's helpful
  14. #29
    Moderator
    PremierD's Avatar
    Jun 2009
    That would not be a good Idea mate ... believe me ...
  15. #30
    Nov 2010
    Quote Originally Posted by khalilo814 View Post
    no chance mate. against forum rules. not that i will distribute anyway.
    if u need a password just ask
