Page 3 of 5 FirstFirst 12345 LastLast
Results 31 to 45 of 67
  1. #31
    Top Poster charlie-h's Avatar
    Sep 2009
    Up North
    Default passwords
    Mate, the passwords that you can generate, are they for all merc vehicles and all the different control units or just a few control units. EG SRS, AC, IC.
    On sprinter and vito you need a six digit password, but after das 07-10 then merc changed the passwords to letters and numbers to make a longer pass key.
  2. #32
    Member 4ly-syk's Avatar
    Nov 2010
    Quote Originally Posted by charlie-h View Post
    i can generate the vito ones and the contol units for the cars;
    i dont know about 07/10 havent used it yet
  3. #33
    Nov 2010
    hi
    Is it working? tested? and please send me in pm thanks a lot and I send you something you may need
  4. #34
    Dec 2010
    works...works...
  5. #35
    Sep 2010
    is passwords calculator!PM and there will be something.
  6. #36
    Apr 2010
    Russia
    Hello, and where you can download das unlock 1.2 or other versions das unlock?
  7. #37
    Dec 2010
    das-password is..
    Many parts of DAS are restricted with passwords that even the dealers have to request. These passwords unlock special functions and restricted areas of the program , including ECU OffLine Coding (programming) .
    Allows you to access :
    Air Bag (Cars)
    Air Bag (Vans)
    Instrument Cluster (In DAS)
    Diesel Particulate Filter
    Off Line Coding (not scn)
    204 Access In DAS
    Electronic Transmission Control
    Adaptive Braking System (ABR) Special Fuction 1
    Adaptive Braking System (ABR) Special Fuction 2
    Electronic Stability Program (ESP)
    Air Conditioning
    Balance EGR CD12
    Balance EGR CD14
    211 RWTS Rear Door
  8. #38
    Jun 2010
    Hello, i am having a problem with a sprinter 906 that i had to change the engine
    The car had an engine, now i changed the engine and the ecu that i am having now it supposed to be the ecu of the new changed engine.
    When i turn ignition on the lights go on, and all the lights in instruments are turned on for example.
    I am not having "start error" but with DAS i found out that there is no start authorization or something like this.
    I have STAR and BDM, and i hope i can solve this problem without going to dealer for SCN coding.
    Any idea?
    Thank you!
  9. #39
    Sep 2010
    PM email address send 1.2-1.6
    Quote Originally Posted by sanek2xlc View Post
  10. #40
    Jul 2010
    hello
    i need password for w204 ESP
    VIN:WDDGF41X88F033102
    DATE: 06/01/2008
    THANK U
  11. #41
    Nov 2009
    workshop
    Quote Originally Posted by auto coding View Post
    hello
    DATE: 06/01/2008
    THANK U
    F8MHD2MMDE
  12. #42
    Jul 2010
    Quote Originally Posted by mercis View Post
    F8MHD2MMDE
    dear mercis
    does it work with ESP?
  13. #43
    DK Veteran cange's Avatar
    Jul 2009
    Lithuania
    hi i have w221 and none o this programs not worked for my
    whay is that?
    my das is 03/2010
    currernt date 17/12/2010
    vin wdd2210222a085429
    thanks for any adice
  14. #44
    Dec 2009
    Quote Originally Posted by cange View Post
    whay is that?
    my das is 03/2010
    http://www.digital-kaos.co.uk/forums...22/index3.html
  15. #45
    May 2010
    hello
    DATE: 06/01/2008
    THANK U
    129073 - here you go
