Page 1 of 5 12345 LastLast
Results 1 to 15 of 67
    Top Poster charlie-h's Avatar
    Up North
    Default Mercedes DAS passwords
    I have noticed that the original thread was closed as it got slightly diverted off the subject.
    My question is can someone check my SRS key gen to see if i am activating the right pass code. The pass code i require is for 639 vito and 906 sprinter SRS airbag.
    The reason i ask is that DAS says incorrect password although i have set my system date correctly.
    I know that we can not post key generators so if any one can help PMS are fine.
    workshop
    use older version DAS
    pw "flexecu"
    new version dont work
    Sep 2010
    Quote Originally Posted by charlie-h View Post
    The passord generator you are using will not work on the vans. post your vin and system date please
    DK Veteran cocoh's Avatar
    Jun 2009
    hi..
    here are some pics with W204 on DAS... only simultaion...
    so.. how to perform this settings in XENTRY?????
    have a nice day..
    Sep 2010
    @charlie-H
    I provided a couple of van passwords by pm, did they work?
    Up North
    Default The code has to be 6 numbers
    Thanks to everyone who sent me pm with codes.
    The codes supplied to me did not work as they have to be six numbers only.
    The reason i know is because i saw it done by a guy from a dealer a while ago, and the entry box will not accept any letters only numbers.
    Please try it in das simulation on vito 639 and sprinter 906 ( SRS ) and you will see it will not accept letters only numbers
    Please get back with any progress -- thanks
    drakov's Avatar
    Aug 2008
    Did you enter the letters as lower or upper case? I have seen some programs that won't accept lowercase letters (making it look like it's only numbers), just a thought and may not be relevent in this case.
    Check out The Number 1 Resource for all Automotive Software with a lot of patience you like me will find what you need...
    yes,mate
    you are right!
    For transporters special settings you need another calculator,..not icab !
    Up North
    Default What to do next !
    Thanks drakov and weryo for your input. Weryo i am glad you agree that numbers are required for the pass.
    I have access to a calculator that generates six numbers. The problem is DAS does not accept the code or says inncorect code.
    The system date is ok and the version of DAS is 07,09 that should accept the code.
    Is there more than one six digit calculator about?
    Can any one test mine by giving me a vin number?
    Or shall i supply a vin number and see if the pass compares to mine.
    If any one has any more options then suggest away!!
    Up North
    Default Please check these generated codes
    Can anybody comfirm that these vins and dates generate the same codes i have produced. These are only test vehicles but it will comfirm that the password gen is working ok or not.
    WDB2110751A123456
    25/10/2010
    code 268971
    WDB2110751A654321
    25/10/2010
    code 283676
    I am useing this generator for vito and sprinter SRS.
    I know these vins are not for vito and sprinter they are just to test the generator
    WDB2110751A123456
    25/10/2010
    code 268971
    WDB2110751A654321
    25/10/2010
    code 283676
    Hi there,
    I also need Das Pass v1.2 , I have the Das smart calculator but the password that i need must be from numbers onlly
    cheers!
    Up North
    WDB2110751A123456
    25/10/2010
    code 268971
    WDB2110751A654321
    25/10/2010
    code 283676
    Can anyone check that these codes are correct for the vins and dates.
    Thanks!!
  13. #13
    DK Veteran cocutanu's Avatar
    Jun 2009
    This is what you need tested ?
    Are you sure this is the right keygen for what you need ?
  14. #14
    impactops's Avatar
    Why dont you PM him the correct one cocutanu
  15. #15
    Jun 2009
    Quote Originally Posted by cocutanu View Post
    this its old version...
    he needs das unlock 1.2
