Page 1 of 5 12345 LastLast
Results 1 to 15 of 67
Hybrid View
    Top Poster charlie-h's Avatar
    Sep 2009
    Up North
    Default Mercedes DAS passwords
    I have noticed that the original thread was closed as it got slightly diverted off the subject.
    My question is can someone check my SRS key gen to see if i am activating the right pass code. The pass code i require is for 639 vito and 906 sprinter SRS airbag.
    The reason i ask is that DAS says incorrect password although i have set my system date correctly.
    I know that we can not post key generators so if any one can help PMS are fine.
    Nov 2009
    workshop
    use older version DAS
    pw "flexecu"
    new version dont work
    Sep 2010
    Quote Originally Posted by charlie-h View Post
    The passord generator you are using will not work on the vans. post your vin and system date please
    DK Veteran cocoh's Avatar
    Jun 2009
    hi..
    here are some pics with W204 on DAS... only simultaion...
    so.. how to perform this settings in XENTRY?????
    have a nice day..
    Sep 2010
    @charlie-H
    I provided a couple of van passwords by pm, did they work?
    Sep 2009
    Up North
    Default The code has to be 6 numbers
    Thanks to everyone who sent me pm with codes.
    The codes supplied to me did not work as they have to be six numbers only.
    The reason i know is because i saw it done by a guy from a dealer a while ago, and the entry box will not accept any letters only numbers.
    Please try it in das simulation on vito 639 and sprinter 906 ( SRS ) and you will see it will not accept letters only numbers
    Please get back with any progress -- thanks
    Aug 2009
    yes,mate
    you are right!
    For transporters special settings you need another calculator,..not icab !
    Sep 2009
    Up North
    Default What to do next !
    Thanks drakov and weryo for your input. Weryo i am glad you agree that numbers are required for the pass.
    I have access to a calculator that generates six numbers. The problem is DAS does not accept the code or says inncorect code.
    The system date is ok and the version of DAS is 07,09 that should accept the code.
    Is there more than one six digit calculator about?
    Can any one test mine by giving me a vin number?
    Or shall i supply a vin number and see if the pass compares to mine.
    If any one has any more options then suggest away!!
    drakov's Avatar
    Aug 2008
    Did you enter the letters as lower or upper case? I have seen some programs that won't accept lowercase letters (making it look like it's only numbers), just a thought and may not be relevent in this case.
    Check out The Number 1 Resource for all Automotive Software with a lot of patience you like me will find what you need...
    DK Veteran cocutanu's Avatar
    Jun 2009
    This is what you need tested ?
    Are you sure this is the right keygen for what you need ?
  11. #11
    Jun 2009
    Quote Originally Posted by cocutanu View Post
    this its old version...
    he needs das unlock 1.2
  12. #12
    Quote Originally Posted by cocoh View Post
    yes, that should be the right keygen, I usually don't ask but I didn't found it anywhere and if can you send me a PM with it I will be more than thankful.
    Thank you very much!
  13. #13
    Jun 2009
    UK
    Hey guys.
    We are trying here to correct the Vmax on Sprinters EDC15 and EDC16. Do you know links to login generators to work on it with MB DAS?
    Any useful info would be very appreciated. Thanks!
  14. #14
    Nov 2009
    workshop
    Quote Originally Posted by worldiagnostic View Post
    Hey guys.
    EDC 15c6- no problem
    EDC 16 hard shop,i think with Ecusafe,from flash possible
  15. #15
    impactops's Avatar
    Why dont you PM him the correct one cocutanu
